Question about Sony Playstation 3 (PS3) Console
Dns problem, can not estabilish acces to ineternet
Scan founds router, wep key is correct, but i got some dns problem which means i can't estabilish connection :/
    Problem Solver:
  • 6 Answers
Ya need a new internet cord if you have it wired same thing with my freinds ps3.or ya didnt do the internet correctly
Posted on Oct 03, 2009
I trying to setup a wireless network wot is the wan ip address and subnet mark/gateway/primary-dns/secondary-dns
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jul 09, 2011 | Computers & Internet
What is a wireless network connection network key also called a wep or wpa key. Or where can i find it?
Both are security protocol which enable the owner of an wireless network to limit the acces to that network and to protect the data that runs through that network.
WEP stands for WIRED EQUIVALENT PRIVACY and it' a security algorithm designed for wireless networks with the intention to provide a level of confidentiality close to the wired networks
WPA stands for Wi-Fi Protected Access and it's a security protocol designed to secure wireless networks
If your wireless device discovered a network that require such keys,that means that the owner of
that network secured his network,only people having acces are those who know the key.
If you have a Wi-Fi router and you forgot the key ,you have to acces the configuration page of the router ,go to wireless security page and reconfigure it, by changing the key.(get the manual of the router and follow the steps)
Feb 19, 2011 | Computers & Internet
I'm juz bought my new xperia8 few days ago..i'm hv some problems to acces to my facebook..hope u can help me...tq
Hi, sounds as if its your routers DNS (Domain Name Servers) settings which are incorrect.
Not having the correct DNS settings can mean webpages cannot be viewed as your router cant read them.
Your ISP can usually sort this out for you if you ring them, they will walk you through accessing your routers set up page and editing the DNS numbers to the ones that are required.
Hope that helps
Jan 09, 2011 | Computers & Internet
Ps3 slim dns failure???
Turn off the PS3......
reset your router,
Power on the PS3
Reconnect.
If that doesn't solve the issue, then make sure the wep key is correctly entered in your network settings on the PS3.......
OR.......
Disable WEP Security on your router.
Mar 03, 2010 | Sony Video Game Consoles & Games
WHAT IS DNS ERROR ANDHOW DO I FIX IT
DNS error is already an issue with the Access Point you are connecting with.
If you are using your own access point, try to restart it. If the same still occurs, hardcode the DNS of your provider on the wireless router you are using.
Hope this helps.
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Nedd the wep key for the psp to go on ineternet
i dont believe you can get it from the operationg system for security reasons. Your best bet is to reset the router and enter new security settings.
Apr 04, 2009 | Microsoft Windows Vista Home Basic Edition
I cant lock my wireless route.
first acces your router with this link
http://192.168.0.1
http://192.168.1.1
then type username "admin"
pasword also "admin"
or blank.
then set your router as wep then set security key means encryption key .
Jan 10, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Dns error
Have you entered the following?
1) Your SSID (typically the SN of the modem/router) 2) WEP 'enabled' and the WEP key
Nov 17, 2007 | Video Game Consoles & Games
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
