Question about Brother FAX T104 Plain Paper Thermal transfer
Copies with the Brother Fax-T104
When I try to make a copy of a document in my Brother Fax-T104 and I press the Copy button twice as instructed, all I get is a triple sound but nothing happens. Any suggestions?
  • Brothered Dec 25, 2007
    Dear Logjam,
    Thanks for your response. Yes, I can send a normal fax. And in the past I have been able to make copies. At first I thought the problem was a matter of introducting the paper for the copy. But recently, once I've verified that the paper ia properly placed, it still doesn't work.
    Otherwise, it's a great little machine for faxes.
    Thanks for your help.
    Tim Fox
    I'm sure you're right that the cost of the machine doesn't justify an exhaustive answer, and if I didn't have my wife breathing down my neck to get the copying function working, I wouldn't give a flying f... about whether it worked or not. But with the little Mrs. giving me hot air each time she can't make a copy, it is worth seeking a solution. Yes, we have a scanner, but it isn't enough for her highness, so I am seeking a solution.
    Best,
    Tim Fox
    Scholar:
  • 159 Answers
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Posted on Dec 24, 2007
  • Rob Fauchon
    Rob Fauchon Dec 25, 2007
    The triple "beep" that you hear is because the paper is not detected by the read sensor. Now, if as you say you can send a fax normally, then the logic of one of the gates is faulty, or being changed by a false input. These gates are integrated in a chip somewhere on the main fax board. The problem could be as simple as a stuck button, or as complex as a faulty chip. I have in the past "cured" a problem like this simply by hitting all the buttons one at a time. If this don't work, try and get another machine, rip out the circuit board and exchange. Best of luck
When I press copy button it will not copy
The key sheet in the control panel is faulty, replace it
Dec 27, 2013 | Brother IntelliFAX 1270E Plain Paper Fax
Want to use HP 1040Fax machine to make copies
1. Turn the page face down and insert it into the document feeder.
2. Press Copy twice.
2. Press Copy.
Number of Copies then 01 [01-50] will display.
3. If you want more than one copy, use the phone pad to enter the number of copies.
4. Press Copy to start copying or press Start/Enter to go to the next option.
Zoom Rate then 97% will display.
Dec 05, 2011 | HP 1040 Plain Paper Inkjet Fax
Printer will not print more than one copy even though I have selected more than one.
Press the 'copy' button to change the printer from 'fax' to 'copy' first, then enter the number of copies you require, then press start - if you enter the number of copies when the printer is still on 'fax' and then change to 'copy' the number of copies will reset to '01' (this is to stop you printing a telephone number of copies by mistake).
Apr 17, 2011 | Brother MFC-465CN InkJet Printer
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
Ned user manual for brother mfc 210
Hi
To copy a page in Brother MFC210 you need to press copy button on your printer, load your document and press black copy (to copy in BW) or color copy. You can also select number of copies by pressing keys 1 to 99 before pressing black copy or color copy button.
For your user manual you can visit this link---
Brother MFC 210 User Manual
Daniel Scott
Jun 12, 2010 | Brother MFC 210C All-In-One InkJet Printer
Can an all-in-one printer be used without a computer?
yes, you can make a copy and fax but you can,t scan any document ....
for fax you have to connect the phone cable to the printer and for copy the document press the copy button and put the document in the upper paper feeder
Dec 28, 2009 | Lexmark X2550 All-In-One Printer
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Fax T 104, can recieve but not send. Can hear the fax signal fro
When you hear the fax signal press the start button on your machine. If this does not work attempt to just make a copy of a document without sending to test the document feeder - help the document by gently pushing the document into the machine when it should be feeding. If you can feel the machine trying to grab it but it doesn't have enough strentgh or it will feed with your help then the feed rollers are probably dirty and you may be able to open up the top cover and clean the rubber rollers with alcohol or degreaser. If the feed rollers do not even turn when trying to make a copy then you may have a motor, belt or clutch problem. If it copies well but will not send, then you will probably have a modem or fax lead problem. Try a new fax lead.
Jul 08, 2009 | Brother Office Equipment & Supplies
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Brother FAX T104 Plain Paper Thermal transfer Logo
261 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
