Question about Iomega Computers & Internet
My iomega hard drive won't be reconized by my mac anymore.
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 03, 2009
Testimonial: "Great tips, I've done some of these steps in previous issues. Thank you, I have already fixed the drive using the disk utility. "
2 Suggested Answers
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Posted on Feb 08, 2009
My iomega 1tb is "read
Any Hard drives before getting to used with MAC OsX has to be formatted according to the MAC file system...
I think that is the problem you are facing...
Make sure your hard disk is not formatted for any windows OS and try to reformat for MAC OsX...
It should work...
Dec 09, 2010 | Iomega 33089 250 GB Hard Drive
Describe your external hard drive iomega MDHD500 Problem: I've just bought a MAC OSX computer which doesn't recognise my iomega hard drive (used on a PC) is there a way to fix this?
Are there any files on the disk-drive that you want to keep?
If so, connect it to a PC, and copy those files.
If not, connect it to the Mac, and allow the Mac to 'format' the drive, to initialize it for use on the Mac.
Oct 25, 2010 | Iomega Computers & Internet
Could not find pretige iomega icon on my computer
format the harddrive as MS-Dos to be able to use it on Mac and PC.
Apr 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
Cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Sep 17, 2009 | Iomega (33090) 250 GB Hard Drive
My portable hard drive was working . Then one day it would not reconize my hard drive anymore ? How do I fix this ?
Try to boot in bios and reset defaults.Connect drive in different usb ports and check. Check usb cables. Try to do system restore.
Aug 18, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Beeping noise
Check the drivers for the hardware.
Jun 12, 2009 | Iomega Silver Series 320GB 3.5 External -...
Mac driver for Iomega 160 USB
http://www.opendrivers.com/driver/217203/iomega-hard-drive-driver-v3.0.4-mac-os-8.6-9.1-free-download.html
Mar 19, 2009 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Computers & Internet Logo
1,261 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
