Question about Maytag MZD2766GES Side by Side Refrigerator
Fridge not working, but freezer is
I have a side by side refrigerator. The freezer is working but the refrigerator is not. I have checked the doors and I also checked to make sure nothing is blocking the vents. I also unplugged it and then plugged it in again to see if it needed to be reset. The fridge is 6 years old and we have never had any problems before.
  • ocean1908 Oct 03, 2009
    so what do I do to fix it?
  • Scott Smith Oct 04, 2009
    The frig is warm but freezer works The coils were froze up in Freezer. Why did the defrost coils not do there job ? How does the frig get its cool air is there electric dampers or are they manual Is there a diagram to see what I can look for.
  • 71 Answers
That would be a defrost problem....there are a few things it could be. There is a switch called a terminator switch that sits on the coils that should read closed when below 25 degrees. You can check the the continuity across the heating element that should read closed at all times....the last would be a defrost control board that sits on the refrigerator side very top right side( you need to remove a few screws to drop the top to get to it)that usually is what the problem is
Posted on Oct 03, 2009
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
I have the side by side fridge/freezer and the fridge side does not seem to be working, however the freezer is fine. Would anyone know why please?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge working not cold no freezer section
first you should check the termostate how much temp you keep.then if your compressor is working properly so check the refrigerant in system.it may be more chances lake of the refrigerant.oil increase in L.P side.you also should check the thermostate is proper working or not.chaces of low pumping in the comp.either door gasket likage or freezer door ofently open.
Feb 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side works fridge side doesnt
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag MZD2766GES Side by Side Refrigerator Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
