Question about E-Machines eMachines Desktop PC
WE HAD VOLUME ON THE COMPUTER BUT ONE DAY THE SOUND WAS GONE
WE HAD VOLUME ON THE COMPUTER BUT ONE DAY THE SOUNDS ARE ALL GONE SO WHAT DO I HAVE TO DO TO GET SOUNDS ON IT AGAIN?!
    Problem Solver:
  • 18 Answers
Get a new sound card or try other speakers and volume ajustment
Posted on Oct 03, 2009
Why has my volume gone mute?
Have you accidentally turned all sounds off? I'm guessing Volume was turned off somehow.
1) Turn the phone off. 2) Restart phone. Don't touch volume controls yet. 3) go to 'Settings' and find 'Sounds'. Touch 'Sounds'. 4) go to 'Volume' and set every one to the maximum. 5) Call a friend and ask him/her to call/text/message and everything else. Does it work?
If that doesn't fix it, go to the last App or Widget you downloaded to your phone before the problem began and uninstall it. You can always re-install it. Sometimes Apps or Widgets mess with Sound and other settings in our wonderful mobile/cell phones.
If that doesn't fix it, you can always try any retail cell phone store and just ask. Most of them, when they aren't really busy, like to solve problems. They do it all day long.
Good luck.
Aug 19, 2014 | Alcatel One Touch C750 Cellular Phone
Sound has gone bad
Which operating system ?
XP If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it if his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer W7 click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps.
Dec 20, 2012 | HP Pavilion BV704AA p7-1020 Desktop PC -...
My e-omachines desktop EL 1200-06W SPEAKERS STOPPED WORKING ONE DAY WORKED NEXT DAY DIDN'T TELLS ME AFTER I GO THRU CONTROL PANEL AND ALL THAR NO DEVICE FOUND . CAN YOU PLEASE HELP ME?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 04, 2011 | Computers & Internet
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
I have already installed the sound card but now its gone.
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 22, 2011 | Computers & Internet
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
also
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
I have a problem of my sound on my pc would you please help me..i dont know how i fix ..strat whn i fix my yahoo..then my sound is already gone..
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Jan 31, 2011 | Computers & Internet
Sound no longer works seems as if the software for it is gone?
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | ASUS Computers & Internet
I had sound on computer when i put on windowsxp pro sound gone
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | EPoX (EP-8KDA3J) Motherboard
No Sound
Have you tried checking if the volume control is locked?
To unlock it, you have to press the < > and the menu button simultaneously to unlock it.
Aug 04, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
