Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
My Malibu light timer gets stuck at the time they are supposed to turn on AND at the time they are supposed to turn off. So if I turn them on manually, they stay on all night if I am not awake to go out and turn them off manually as well.
    President:
  • 1,723 Answers
The small motor that runs the time clock is bad. If it stops the motor when it comes to the start and stop clips, it's done. Replace it.
Posted on Oct 03, 2009
Part of a malibu light timer runs but the timer dial does not turn to turn lights on/off
Clock motor has stopped working... there is not replacement module.
Plug power pack into wall timer.
Following link has troubleshoot, warranty, and installation tips to avoid problems:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#troubleshoot
Gene
Water Heater Timers Save Money
Mar 22, 2015 | Malibu Hardware & Accessories
My malibu timer seems to get stuck before turning itself on. It take 1 hour to trip the timer to come on?
1) Clock motor is worn out, or gears are dirty:
2) Take apart clock motor and add white grease to gears
Set override to ON, and plug timer into cheap wall timer.
Take advantage of 5-year warranty.
Mar 10, 2013 | Malibu ML300RTW - Low Voltage Power Pack...
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
Malibu Lighting ML300RTW Transformer Motor
Motor has gotten weak, and is overheating and soon will not work.
Some people report taking apart motor and cleaning gears.
Others report that they didn't record how the gears came off, and can not reassemble.
PB912M10 Clock module is not sold separately.
Switch power pack to override so lights are ON, and plug transformer into cheap wall timer.
Copy following link for tips to get power pack to last longer, troubleshoot, and warranty, etc.
Nov 04, 2012 | Intermatic Malibu 300W Power Pack...
Describe your Malibu 600W Power Pack Transformer Problem When it is time for the low voltage lights to come on the timer can not get past the pin to turn it on, however when I turn the timer dial it...
When dial gets stuck at tripper, then clock motor has gotten weak.
1) Some people report taking apart the clock motor, cleaning gears, and adding vaseline to gears.
-Some people write and ask how to put gears back together after taking timer apart.
-Some people find the gears are stripped.
-There are no replacement clock motors or timer modules for Malibu/Intermatic timers.
2) Easiest solution might be to buy cheap plug in timer, set power pack to override, then plug power pack into cheap timer.
3) Power packs come with a warranty, but warranty requires sales receipt.
-Open following link for resources including warranty.
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Intermatic Malibu 300W Power Pack...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
It has stopped clicking over so my lights won't go on a night. I unscrewed the top but I can't get the timer out. Seems to be stuck on the post that that turns the lights on or off. Help!
If you undid the dial it may not be repairable. Try to replace the dial if you can. With the dial in place there should be some wedge shaped pieces with screws that attach to the dial. They're usually black and white or gold and silver. The white or silver usually turn on the timers switch and the black or gold usually turn it off. To set the time pull out on the dial face and turn it to the correct or near correct time. If the dial doen't turn then the timer is most likely burned out.
Jun 11, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
956 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
