Question about Garden
My John Deere 14sb walk behind mower will start, and then within three seconds, it will die.
  • 437 Answers
Sounds like after the prime fuel is burnt up, it dies. This sounds like either a jet is clogged up or a diaphragm, depending on your carburetor, needs some attention. Look at what engine you have on the mower. You may be able to clean the jet, depending on your mechanical abilities, yourself.
Posted on Oct 03, 2009
Testimonial: "The suggestion for the jet being clogged was right on the money. Thanks for the info. "
How do you replace the clutch on John Deere 14sb walk-behind mower
I dont know if this is servicable.you may have to chuck it out and buy a new one. phone a small engine lawn mover repair shop and get a expert oponion
Jul 15, 2014 | Garden
How do you replace the clutch on John Deere 14sb walk-behind?
google your question. all sorts of help popps up
John Deere Walk Behind Mower
remove the tin cowling and check for rubbish build up preventing the air cooling the fins of the motor.
Jun 14, 2013 | John Deere Garden
John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Aug 09, 2009 | Garden
Engine won't run unless the choke is on - Deere 14SB Push Mower
It's starving for fuel. When you push the throttle all the way forward it closes the choke. You took it apart but you probably didn;t get all the junk out of it. Easy fix is to put some SeaFoam into the tank and run it. This cleans all deposits and debris from the jets. I have used this stuff and put it in the tank and start the engine and sit back and let it run. After about 5 minutes the engine will smooth out and run fine.
Jul 30, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Garden
Garden Logo
610 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
