Ford 8n,9n,2n,  Tractor Starter With Drive
Problem for Ford 8n,9n,2n, Tractor Starter With Drive
Turns over not starting changed points
By daddiebear67 on Oct 03, 2009
turns over not starting changepoints
Best Solution
posted on Oct 03, 2009
Very Helpful)
dunnnutt
Rank: Guru
Rating: 86%, 18 votes
Verify the point gap is set right and that you are getting a good spark. Check to see if you are getting fuel to the carb.
John
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 20, 2009
Helpful)
498n
Rank: Guru  Ford Expert
Rating: 91%, 190 votes
Was it running before the points change?
If so...go back into the dist and check for proper point gap and check for grounded wires/connections in the dist.
if it was not running before the points change....did you check for spark?
Did you check for fuel?
Where the plugs wet or dry?
Wet plugs may mean lots of fuel........and no spark.
Are the plugs back?
It won't start on carbon coated plugs.
Are you getting battery voltage to the coil from the key?
Was this helpful?
Yes
No
Solution #3
posted on Nov 01, 2009
Not Rated)
juan007
Rank: Apprentice
Rating: 0%, 0 votes
I have a craftsman lawn tractor lt1000 model #917.272084. The engine runs but very weak and eventually make explosions and then it stops running. Can you please help me figure out my problem. Need to cut my lawn soon.
Was this helpful?
Yes
No
Popular Solutions for Ford 8n,9n,2n, Tractor
Questions and Unsolved Problems for Ford 8n,9n,2n, Tractor
Do you recommend Ford 8n,9n,2n, Tractor Starter With Drive?
Answer
Answer
I have a 4 stroke ride on mower - engine starts but runs properly then tends to die out - runs... (More)
Answer
where in the heck does the condencer mount in the distributor. please help.I have worked on it all... (More)
Answer
I am getting no spark to plugs or coil is getting fuel could it be voltage regulator or solinoid... (More)
Answer
2000 ford Escort ZX2. 4Cyl. Has no spark at spark plug. Wires are good. It is getting fuel.
Answer
want to put a new amp meter on the 9 n tractor i have 6 volt.the other one was not hook up.would... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ford 8n,9n,2n, Tractor...:
Top Riding Mower and Gar... Experts
Rank: Guru Guru
Solutions: 3951
Experience: ten years experience,school trained,own business
Ask Me
Find more Riding Mower and Gar... Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
