Question about Honeywell Programmable Thermostat Heater
I have a Honeywell programmable thermostat that I've had for many years. Recently the batteries went dead. We replaced them, reprogrammed it and started the furnace up. When we came home after and hour or so, the house was hot and the thermostat temp showed 50 degrees when it was actually 74. The furnace kept running because it read 50 (I believe). We shut it down to stop the furnace.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Bad tstat or installer setup on one of the wrong settings
Posted on Jun 09, 2013
  • Honeywell Expert
  • 252 Answers
Go to myhome.honeywell.com and search for a manual for your model number thermostat on the right hand side of the page
Posted on Oct 04, 2009
Reset after power outage
Most programmable thermostats have batteries to keep the program from being lost in a power outage. If you thermostat has dead batteries or no batteries a power outage will cause the thermostat to revert to a default setting and it will have to be reprogrammed. Hope this helps.
Dec 22, 2013 | Honeywell Heating & Cooling
Honeywell digital thermostat went blank, ac unit wont come on, its an 8400c, no breakers tripped
This thermostat has batteries. Try replacing the batteries. You may have to reprogram and make sure it is on.
Jul 18, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I replaced the batteries in my Honeywell CT3300 and the "Bat Lo" message won't go away even with fresh batteries. Is there a reset button or something?
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Oct 14, 2009 | Honeywell CT3200 5-2 Day Electronic...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Air suddenly not coming on Honeywell RTH230B
for starts, check fuses in disconnect box by condensing unit
Aug 20, 2009 | Honeywell Programmable Thermostat Heater
I replaced the batteries after seeing a display of "EEE" and since then I get no display whatsoever. Honeywell/36
The internal sensor could be bad, try replacing the batteries again, be certain the polarity is correct, the sensor is inherent to the stat and the stat must be replaced.
Jul 19, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm IV Plus requires frequent resetting.
Check to see if you have wires going to a C/C1 terminal. The older chronotherms used a transformer to supply 24 volts to power the clock. If in fact you do have these terminals, then I would suggest checking the output voltage on the transformer, (secondary (24v)side) to ensure it isn't close to dead. Hope this helps
Nov 28, 2008 | Honeywell Programmable Thermostat Heater
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Heating & Cooling Logo
383 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
