Question about Electronics - Others
What do you mean by insert a disk removable disk
    Sergeant:
  • 233 Answers
Insert a removable disk, means to place in the appropriate drive one of the the following:
a. floppy diskette
(Usually a 1.4 meg floppy disk) Rapidly becoming obsolete
b. CD disc
c. DVD disc
d. Blu-ray disc
e. Thumb drives
Removable Disk
Also known as removable storage and removable media, a removable disk is a type of media that enables a user to easily move data between computers without having to open their computer.
Hope this helps!
Posted on Oct 04, 2009
Can not insert disk into imac
Assuming of course the iMac is otherwise running and functioning normally, this would indicate that the drive has gone bad. Usually, when you first turn on the computer, you'll hear the drive make a sound. If this is not happening, either there is a disk stuck in it or the drive is defunct. visit this page for some tips on ejecting a stuck disk. If that does not work, you will need to replace the drive.
Apr 18, 2013 | Apple iMac Computers & Internet
Cant get past the start window
The main problem is the hard disk switch off the laptop and remove the battery from its compartment then remove the hardisk cover and remove the hard disk from its compartment now replace the cover and insert the battery to its compartment and switch on your laptop and see wether the system show boot error if you can see the boot error and when you connect the hard you doesnt go till there it means you have a problem with the hard disk
Dec 30, 2011 | Sylvania G-Netbook
HOW DO I FLOORMAT A SD CARD?
maybe u mean FORMAT a SD Card
for formatting an SD Card, u need an card reader on your computer, insert the card and it will be displayed as a removable disk. You right click the removable disk and click format
Sep 13, 2011 | Kodak EasyShare V530 Digital Camera
Please insert disk
This usually means that the motherboard cannot access the disk-drive on which you have stored your copy of Windows.
Check that the disk-drive is getting electrical power.
Check that the "data" cable to the disk-drive is tightly connected both to the disk-drive and to the motherboard.
Check in BIOS SETUP that the disk-channel is not "disabled".
So, the motherboard tries to boot from the CD/DVD drive, and/or from the 3.5-inch diskette-drive,
after you "insert disk".
Or, it could mean that your disk-drive has "died", and needs to be replaced.
It's time to take your PC to a professional technician.
Aug 02, 2011 | Computers & Internet
My syastem was working properly since five month don"t no suddenly what happned after swiching on the computer its showing like DISK BOOT IS FAILURE, INSERT SYSYEM DISK AND THEN PRESS ENTER ....... i amnot...
this means, there is no bootable disk detected. Make sure there is no floppy drive inserted to the system and remove external storage devices, then try to remove and reconnect the hard disk. Make sure your boot method is set to use the hard disk with your OS installed. If this does not work, you may have to reinstall your operating system. If this fails, it may indicate a failed hard disk and you may have to get in touch with your vendor for warranty replacements if needed. hope this helps.
Aug 29, 2010 | Computers & Internet
Hard disk is detected in BIOS setup, but after boot it shows "DISK BOOT FAILURE, INSERT DISK" So what can i do now
it means insert your copy of windows operating system to finish the installation if you already have a operating system on your hard drive and if you dont wish to remove it when in bios scroll down Adavanced bios features and change settings on first boot device
Aug 27, 2010 | Computers & Internet
What is mean when you open your usb flashdisk and said that insert disk to any drive like drive e
when you insert your usb stick into the usb click on my computer and it will be listed theyre it will say removable disk A,F,G, etc. that is what is meant i hope this helped.
Jul 12, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
No disc inserted
That means there is no disk inserted. Unless it's apirated copy mounted on the computer. Then for that you need a cracked file for that game.
And if the disk is inserted and it says that, then check out your disk or disk drive.
Hope this helps.
May 10, 2009 | Video Game Consoles & Games
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Electronics - Others Logo
362 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
