Question about Sharp 27J-S100 TV
Picture converges to the center -- "funnel" like
How can I correct a "funnel" picture on the Sharp 27J-S100?
  • 1,694 Answers
1) Solder any / all bad connections
2)troubleshoot,locate and replace any bad parts in pincushion
circuit....start with pin amp output.......
3)No problem found ?.........could be bad yoke.................T.
Posted on Dec 21, 2007
Tuner not working and its good all the voltages are there
could be but this is not a extremely expensive set, Sometimes the tuner if bad has bad solder connections on the board INSIDE the tuner, most that do will react to being banged on with set on and signal hooked up, a replacement tuner if available would be rather costly, doe the set have audio/video input jacks on it?
Dec 15, 2012 | Sharp 27J-S100 TV
Problem with degaussing coil locking out main control
Check the degaussing posistor. Replace it with a new on of same type. There are so many types of this component. Might look like these.
Jul 03, 2012 | Sharp 27J-S100 TV
Sharp 27J-S100 How to adjust contrast??
There are actually two adjustment access holes (focus and contrast) on the back of that model. Here is a makeshift map...
On the back of the set mentally divide it to a left and right half. About the middle of the right half and around 4 or 5 inches up from the bench there will be two 1/8" holes. one on top of the other and about 2" apart. Slip a "pocket" sized flat head screwdriver into the lower hole and feel for the blade to enter the slot and gently turn either direction to adjust the contrast to your liking. The other hole above the "contrast" hole is for "focus" and really should be left alone.
The entire back cover can be removed by taking the four screws out of the corners and slipping it off. Then you can actually see the adjustment controls if you find getting that little screwdriver into the hole would be easier with it's clothes off...
*he smiles...*
Dec 16, 2011 | Sharp 27J-S100 TV
Want to see a free online manual for the Sharp 27J-S100 CRT TV--need to know what is the best possible hook-up (HDMI, Component, S-Video, or Composite) for pic quality. Thanks!
CRT-(Tube tv).Dosen't support HDMI cables.S-Video cable.Only on some a 27' and above.Mostly are R,Y,W RCA component cable support work best for the standard below 27" (CRT-tube-tv).
Dec 17, 2010 | Sharp Televison & Video
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
Need a new remote
A Phillips universal remote will work. Just program it for the TV Model. These are about $15 at Radio Shack.
Mar 01, 2009 | Sharp 27J-S100 TV
No picture but there was a sound
1.service mode before putting unit into the service mode, check that customer adjustments are in the normal mode. use the reset function in the video adjust menu to ensure customer controls are in thier proper(reset)position. 2.service number selection once in the service mode, press the channel up or channel down button on the remote transmitter or at the set . the service adjustment number will vary in increments of one,from "S01"~"S19" to "M05". select the item you wish to adjust. number selection press the volume up or down button to adjust the data number. to enter the service mode. while pressing the vol-up and ch-up buttons at once, plug the ac cord into the wall socket and switch on the main power. now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Sep 19, 2007 | Sharp 27J-S100 TV
Tv comes on for a second, then goes off.....
to enter the service mode . while pressing the vol-up and ch-up buttons at once, plug the AC cord into the wall socket and switch on the main power . now the TV set is switched on and enters the service mode. to exit the service mode, shut the television off by pressing the power button.
Aug 21, 2007 | Sharp 27J-S100 TV
Televison & Video Logo
77 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
