Error E000 I got this error, unplugged the machine and the error won't go away. There are no paper jams.
  • 00DAVID Jan 14, 2008
    I have a Cannon D86 multi function copier. Just this morning I ran one copy through and went to run another and the alarm light came on followed by this System Error E000. I have already done the unplug for ten minutes thing suggested by the manual.
    Any Ideas?
    DAP37ATTY@AOL.COM
A specific model and complete code is needed. The error could be numerous issues not only fuser. The fuser is the part of the machine that melts the toner on to the page before exiting the machine. Some fuser codes can be attributed to 'dirty power" in which case the code can be reset through machine diagnostics. Due to the fuser getting very hot, it has several components to control heat, and shut it off (error code) to protect from over heating. Depending on the model, the machine will have at least one thermostat (heat fuse) and a thermistor (monitors temp).
Please provide model number and entire code and I can give you the exact problem and part numbers if needed along with reset procedure.
Posted on Dec 22, 2007
I guess you have a Canon copies, but what model do you have?
E000 on must Canons is a fuser code. It is not getting hot. you may need to enter servive mode to clear the code first, then see if the lamps will on. if not it may be a fuse or bad lamp .....
The machine model or brand is not mentioned,
but if it is canon this code relates to heater [fuser} proplem
2 Suggested Answers
  • 1126 Answers
SOURCE: Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Posted on Aug 05, 2009
Paper jam
You may need to make sure there are no small pieces of paper left in the machine. Unplug it and let it set for about 30 seconds and then plug it back in and let it reset itself. Sometimes a jam can bend some small metal parts and cause it to give an error message. Check for this also. It should clear the error out once unpluged. If it is hardwired into the wall then the breaker will have to be turned off for the same seconds. Hope this does the job for you, all copiers and printers can be a headache when you need them most.
Col. Dana Gillespie
Jul 05, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
No paper jam but error 5110 won't go away
Have you tried unplugging the machine, this might reset it.
Mar 14, 2013 | Canon Pixma MP500 All-In-One InkJet...
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Error button never go away after a paper jam
Sounds like you may still have a piece of paper in the printer. Open the toner door - take out the cartridge, reseat it and then close the door. If the error light stays on you probably have something stuck in the machine. You might need to power it off (unplug it) and then see if there's anything on the rollers.
Jan 28, 2010 | Konica Minolta PagePro 1350W Laser Printer
Error Msg E000
Aug 03, 2009 | Canon Office Equipment & Supplies
Cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
Jan 12, 2009 | Canon imageCLASS D880 All-In-One Laser...
CANON d880 e000 eRROR
THE FUSER YOU REPLACED IT WITH WAS DEFECTIVE
Nov 15, 2007 | Canon imageCLASS D880 All-In-One Laser...
Error Message - System Error E000
Does a page come out? just blank? How old is your cartridge, did you pull the tape out? Need more info to help.
Aug 28, 2007 | Canon imageCLASS D860 All-In-One Laser...
197 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
