Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
Lens does not work. It only takes black picture
My aperture or lens isn't opening - can't take a picture. It worked fine a couple of weeks ago and when I tried to use it this week it was a no go.
Aperture and lens are two different things. If you mean the camera is taking black pictures (something common for the S5), then see this link.
But if you mean that the lens isn't extending properly, then see this video:
Dec 08, 2012 | Canon PowerShot S5 IS Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
Nikon D40 taking blank/black pictures after I wiped my lens.
Try removing the lens and re-fix it.. Some times the lens is not sensed properly if it is not fixed right.
Dec 17, 2009 | Nikon D40x Digital Camera
Black screen; lens won't shut; totally not working now
Sound like the sensor or recoding electronics are bad. The camera is most likely beyond economical repair and I would buy a new one.
Nov 19, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Review windows is black, pictures are black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 12, 2009 | Cameras
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Repair of digital camera
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Nov 14, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
