Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
How do I reset projection lamp indicator - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Don't know
Posted on Oct 03, 2009
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
PT-61LCX65 lamp light flashing. Believe I need to change lamp and reset? Could you tell me how to reset?
Check the owner's manual to be sure. The troubleshooting section should list the meaning of the flashing lights. Typically this is a bad lamp indicator or a lamp life indicator. The replacemetn lamp should include the instructions for replacing the lamp and resetting the lamp life counter.
Dan
Nov 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I need to reset lamp timer
Here is the procedure for reseting the lamp.
It can be found at:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Warning:
Perform lamp time reset only when the lamp has
been replaced.
When lamp time reset is finished, the LAMP indicator goes out.p re placement,z
5 seconds.
LSQC0334 C
LAMP TIME WAS
RESET TO 0.
END
Apr 29, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
How to reset lamp timer
hold down the PIP button on the remote control
simultaneously for more than 5 seconds. You will see a screen pop up that says "Lamp time was reset to 0" and the lamp indicator light will go out.
Dec 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Lamp indicator
look in the customer menus for lamp hours reset
Sep 05, 2008 | LG RU-52SZ51D 52" Rear Projection...
Directions for lamp time reset
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jun 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp Indicator is Orange
Press 'Enter' on the TV then press 'Mute' on the remote while holding 'Enter' down. A menu will pop up on the screen, allowing you to reset the light. It's also worth noting that you can get to the service menu by pressing 'Menu' on the remote and TV at the same time. There is an option for checking the number of hours on the lamp.
Apr 19, 2007 | Zenith E44W46LCD 44" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
