Question about Whirlpool Calypso GVW9959K Top Load Washer
The drum in my whirlpool calypso washing machine has come loose. can it be fixed?
    Sergeant:
  • 186 Answers
This could be caused by a spring disconnecting from the drum inside the machine.First unplug the washer.Pull it away from the wall a foot or so and remove the bottom panel,this should pop off by prying in the seem between the panel and the main cabinet.If it doesn't look for screws which may hold it in place. when removed tip the washer back toward the wall and have a helper hold it.Look for long springs (probably 3 of them)) which hold the drum centered and upright.If one is missing,broken,or unhooked it is the cause of your problem.
Posted on Oct 03, 2009
Our Whirlpool Calypso model #GVW9959KL washing machine has started leaving light colored marks (kind of look like lint, but won't brush off like lint might) on dark clothes. Do you know of a way to...
sounds like you might have mold inbtween the tubs and its starting to wash loose and get on your clothes. try a washer cleaner like washer magic and see if that helps.
Feb 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Wash drum will not fill with water at all
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I need to get under the hub of my washer
Its not easy... do you need to take the steel basket out or just the plastic wash plate? The wash plate is easy enough just pop the center cone up and out by depressing three screwdiver slots around seam. Then some 3/8" bolts secure wash plate. You are suposed to replace some orings every time you remove plate.
Oct 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Can I find a picture of what the top inside is whirlpool calypso
Go to www.repairclinic.com, for a detailed part-by-part breakdown, with pictures.
You could also find other sites by going to: www.homemanagement.services.officelive.com, go to the site map and select "appliance repair help"
Jul 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Topload washer dripping
of course its proably just a water valve leaking
Jan 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
367 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
