Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Light comes on but dont flicker
Our light comes on in the firplace but dont flicker. Would changing the bulbs also correct that
    Problem Solver:
  • 7 Answers
Most likely this is becasee motor driving the "tinsel in a stick" is not working. Take the glass off, remove the fake logs and look underneath to see if the the rod wih the tinsel is turning. If not the problem could be the motor or the speed control. If you have a voltmeter you can test the speed control output - it's 12VDC - of course it will vary depending on the speed sselection. The mot probably cause is the motor has died. You can buy a new one at www.ibuyfireplaceparts.com. Cost is $77.01> it's a bit tricky to replace - just a tight spot is all - 2 small screws and out it comes.
Posted on Oct 04, 2009
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
Why does my Ott light flicker but not come on completely?
check and replace bulb first, if not that then most likely a ballast problem, which sends a boost of the correct amount of power to ignite the bulb then lessens the flow of power it needs to stay lit.
Sep 06, 2014 | Ott Light OttLite Truecolor Table Lamp
2005 T&C brake light and turn signal dont work
Replace the bulb with the one from the other side and see if it works. I bet the bulb is burnt.
Apr 25, 2013 | Chrysler Town & Country Cars & Trucks
Dash gauges and Information center work intermittantly - All fuses are in good
is it the lights of the gauges dont light up or the gauges dont work period? if they dont light up then check the bulbs that are behind the gauge cluster and they could be burnt out i have the flickering prob with my ac hvac controls and half the lights on my gauges dont light up due to bulbs being burnt out i just havent spent the money to get some blue leds to put in there
Feb 20, 2012 | 1995 Oldsmobile Aurora
Motor running but no flicker effect shaft drive
If you check your owners manual it should tell you how to change bulbs etc. Are you not seeing light, or light comes on but no flicker? If you can reply with model number on your unit, perhaps we can guide you to diagnosis and repair easier.
Sep 21, 2011 | Dimplex Compact Electric Flame Stove...
Headlamps flicker when hitting bumps. Notice it more on right side. Lamp ground to body is good. Connector pins to lamp are good. Adjusted headlamps, changed bulb, still have problem. No flicker noticed...
yes i agree, what you have done is what i would have been telling you to check so well done for saving you and me time.first its either one of what you say but its my guiss the headlamp housing is loose after what you have all ready done i think you will find the culpuit quick,TIP,if you find the housing loose try using cable ties they work a treat without haveing to use screws ,any problems dont be afraid to come back to me,adrian,,,,,,,,
Aug 20, 2010 | 1999 Lincoln Town Car
In focus 70+ light flickers
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Aug 06, 2008 | InFocus LP70+ Multimedia Projector
Ecoquest FreshAir - UV Flickering
UV bulbs, or rather the RCI cell needs to be changed every three years in the FreshAir, or when the "Replace RCI cell" appears, whichever comes first. The UV bulb loses its intensity over this period of time.
Eric
Download PDF Manual
Feb 17, 2008 | Ecoquest Fresh Air Air Purifier
Heating & Cooling Logo
136 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
