I have an old disk drive that looks like it would be used in a main frame computer. The case looks like one of those pucks used in curling (or a tupperware container for carrying a baked cake). The top has a recessed handle and the bottom piece has a knob in the middle which can be used to open the case. Inside the case there's a group of disks stacked upon one another. Approximately 14'' in diameter. Only marking on it is BASF. I can't find any model number, etc. I would like to know what the proper name for this would be and, if possible, what it would go to. I can send a photo if you tell me where to send it. Thank you. Ron
  • Ron Fredey Oct 03, 2009
    Thanks for the reference. I was able to find the disk listed there.
    Appreciate it!
    President:
  • 2,600 Answers
This is two of the devices made by IBM; not sure if this is what you are looking for, but it's a start. The hard disk drive The first hard disk drive was the IBM Model 350 Disk File that came with the IBM 305 RAMAC computer in 1956. It had 50 24-inch discs with a total storage capacity of 5 million characters (just under 5 MB).
I have an old disk drive that looks like it would - 2398292066_5bdce51007_o.jpg
Above: IBM Model 350, the first-ever hard disk drive.
The first hard drive to have more than 1 GB in capacity was the IBM 3380 in 1980 (it could store 2.52 GB). It was the size of a refrigerator, weighed 550 pounds (250 kg), and the price when it was introduced ranged from $81,000 to $142,400.
Above left: A 250 MB hard disk drive from 1979. Above right: The IBM 3380 from 1980, the first gigabyte-capacity hard disk drive.
Check out this next site, goes over the history of DATA storage.......
http://www.magneticdiskheritagecenter.org/MDHC/Magnetic%20Disk%20Storage.pdf
Posted on Oct 03, 2009
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
Hi i have a a portable WD BAAA5000ABK-00 500 gb hard drive, i dropped it a while ago , and when i connect it to my laptop it spins for like 10 seconds and i hear a ticking sound,then it stops spinnig, i...
You could purchase another identical external disk-drive, and "transplant" your "old" disk-drive into the new case, to see if you can read from the "old" disk while inside the "new" casing.
If not, then re-insert the "new" disk-drive into the "new" casing, and use the "new" external disk-drive as a 'BACKUP' for your files (not to hold the ONLY copy of your files).
Jun 01, 2011 | Computers & Internet
Hi my pc come up with a error boot disk failure bit also i get a blue screen sometimes
You have given little information, but to me it sounds like your hard disk is failing. I would try to get the drive imaged to another one, and replace the drive before you completely lose all your data!
May 27, 2011 | Computers & Internet
My internal CD/DVD drive and Burner quit working. Will not run a CD or DVD. Computer does not even recognize it as a drive. Can this be fixed or what kind of external drive can i get?
As I'm sure you are aware a CD/DVD drive is a mechanical device. It's 'lifespan' is rated in hours of usage. With the C521 being 4 years of age, I wouldn't think the DVD dual-layer burner drive would be defunct. Does depend on how much it's been used.
Ordinarily I would state cleaning the optical eye in the CD/DVD drive, and also reinstalling the drivers, if a disk is not recognized. However the, " Computer does not recognize it as a drive.", statement concerns me.
Suggest you try the software approach first of reinstalling the drivers, then if you wish go on to the hardware approach, of checking to see if the data, and/or power cable is loose on the DVD drive.
Reinstalling the Drivers:
The main method;
1) Left-click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) In the Device Manager list, left-click on the + sign next to Disk Drives.
7) Now right-click on the name of the DVD drive.
Here you will have the options of either Uninstall, or Update Driver.
I suggest you left-click on Uninstall.
Update driver seldom works.
A warning will come up, "Warning you are about to uninstall this device, ya-da, ya-da"
It's okay. Click on OK.
Close all windows, go back to your desktop screen. Shut your computer down normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute, turn your computer on.
After Windows has loaded you should see a pop-up out of your system tray, "Found new hardware".
Plus perhaps another one, "Found XXXX DVD writer"
Still no?
Then it's time to check the above mentioned cables.
Your Dimension C521 uses a SATA optical drive. (DVD drive)
The Data, or Interface cable looks like this,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
(The color of the cable may not be the same, and it may not have a 90 degree elbow connector)
It is a 7-pin connector.
Make sure it is plugged in tightly to the back of the DVD drive, and also to the SATA header on the motherboard.
NOTE*
BEFORE you reach inside your computer!
Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static will Fry Out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, working on a table, open the computer case.
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you get up, an walk away in the middle of working on your computer, upon your return be SURE to touch the metal frame again.
Computer unplugged from power, you're safe. TOUCH the metal frame of the open computer case, your computer is safe.
Here is a link to Dell Support, and the Service Manual for the C521,
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/index.htm
You will see - Removing the Computer Cover, and Replacing the Computer Cover.
In the main menu list you will also see - Technical Overview.
If you click on this heading, and then on - System Board Components, you will see the motherboard in an illustration.
Here you will see the Ram Memory slots. Below them is where the 24-pin ATX main power cable plugs in, (No.5), and to the right of the main power cable are two SATA headers, on the motherboard. (No.6)
Your SATA harddrive plugs into one of these SATA headers, and your DVD burner optical drive, plugs into the other one.
The SATA power cable going to your SATA DVD burner drive, comes from the Power Supply. It's a 15-pin connector. Looks like this,
http://en.wikipedia.org/wiki/File:SATA_power_cable.jpg
Be sure it's plugged in tightly to the DVD burner drive.
It could be a bad SATA Data cable.
More than likely your DVD drive is just toast. Seen the last of it's days.
Your Dimension C521 uses a regular size SATA DVD burner drive, even though it's a Slimline style of computer.
There are MANY drives available, should you decide to replace it.
You can also use one of these drives in an external enclosure. This way you just plug it's USB cable, into any available USB port on your computer.
If I were to recommend a SATA DVD burner drive, I would recommend one of the Lite-On models.
Cost less than most, but have features, and reliability of those that cost 3 to 5 times as much!
I'm using a Lite-On model that cost $48 from a large store, but could have purchased it for $28 online.
It's a DVD SATA burner drive that will support dual layer disks, and has LightScribe Technology.
Has lasted over 4 years now, and a clients computer that I installed the same model, has lasted over 5 years now.
Zero problems.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5204603&CatId=4
(I see they're cheaper now, sheesh!)
Barring you do not wish to open your computer, and replace your DVD burner unit, here is an example of a 5.25 SATA external enclosure,
(A laptop harddrive is 2.5 inches across in width. 2 and a half inches. A desktop harddrive is 3.5. An optical drive is 5.25 inches. 5 and one-fourth inches),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2414551&CatId=2784
If you have any questions please post them/it in a Comment.
Regards,
joecoolvette
Sep 08, 2010 | Dell Dimension C521 PC Desktop
How ot install hard disk?
1. VITAL: unplug computer.
2 EQUALLY VITAL: wait for 1 full minute while board discharges.
3 open side of case.
4. VITAL ALSO: touch your hand to internal metal part of case to discharge static from your body
4 unplug old hard disk, then remove mounting screws from it.
5 remove old hard drive.
6 before handling new hard drive touch metal inside case again. (if you have a static band use it otherwise keep touching the metal case frequently to prevent static from "zapping" your computer parts.)
reverse this order to install new one. it will be recognized by computer on its own.
Jun 23, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I put my old hard drive in as a slave, vista recognises it in management and device manager but doesnt recognise it in my computer?
it might need to be formatted, right click on the computer and click on manage, click on disk management and format the disk.
Mar 03, 2010 | Acer Aspire m5640 PC Desktop
How to send photos from laptop to digital photo frame
The photo frame will either have a card slot or a USB connection on it. If it has a card slot you will need to connect the card to your compuer first (through a card reader) and download the pictures onto it. Then put the card into the photo frame.
If it has a USB connection, you can use a usb flash drive - first plugged into your computer to download the pictures then plugged into the photo frame.
It is also possible that the photo frame has internal memory - in which case you would connect the frame to your computer directly using a USB cable. It would them show as a "Removable Disk" and you can download directly to it.
Nov 04, 2009 | Office Equipment & Supplies
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
SCSIerror0600H failure to start
SCSI is (mostly) obsolete for the desktop market unless you have a specific need with an old product such as a scanner or Hard Disk drive. The usual culprit is the device, if it is outside the case, hasn't been turned on before the computer was turned on. If you don't have any SCSI devices attached you may ignore the warning. If you are using a SCSI Hard Drive as the main drive this failure could prevent the computer from booting.
Sep 17, 2009 | IBM Computers & Internet
Hard Drive Replacement T30
Hey there jlricker, in order to accomplish your task you need an external drive, with the ability to do full copy, from another drive installed in your computer. One such option is EZ Upgrade Kit. It includes the external drive case and data copying software. You can use the case and old hard drive as a regular external when you are done. Good Luck!
Jan 31, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
David Payne
David Payne
