Question about Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHU43C06UC, the timer module was replaced during the recent recall. Before that, the old timer was within a few seconds of the technical information timers guide (page 57): R&H 9 min, QW 35 min, RW 110 min, PSP 138 min. Now with the new module the timers are: R&H 65 min, QW 98 min, RW 116 min, PSP 115 min. My question: Is there a way to reset these times to factory specs?
  • Bosch Master
  • 2,605 Answers
Hi, I have a suspicion when the new control was installed the "programming" may not have been done correctly. You should contact the dealer responsible for the "rework". Failing any help with them I'd suggest contacting b/s/h customer service. To answer the question re; can it be reset to factory defaults ? Answer; sort of. If programmed correctly, you should have comparible cycle times as previously. There is always the possibility the control installed is faulty as well. I know having had quite a few reworks working for Sears, and the rare one was faulty. Hope that helps good luck
Posted on Oct 03, 2009
Testimonial: "Thanks, I will contact Sears. You have been a great help."
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
MY BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. I HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT I...
Hi gwmkjm,
I'm Harvey the Master Plumber.
Your question is: YOUR BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. YOU HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT YOU STILL CAN NOT GET IT TO TURN ON. AT ONE TIME THE LED LIGHT LIT UP FOR A BRIEF SECOND, BUT NEVER AGAIN. ANY OTHER SUGGESTION?
Yes. 9 times out of 10 it's a loose or broken wire in the d/w junction box under the d/w behind the kick plate on the right. Make sure to turn off the electric before you expose the wirenuts. Remove them and install new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Bosch Dishwashers
My Bosch Dishwasher model #SHU43C06UC/17 in 5 years old and has been working great and all of a sudden last week it stopped working. When you try to start a new load it will start the timer, but the...
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
Sep 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My SHE4402UC/36 dishwasher malfunctioned all the lights were flashing and the machine was trying to drain. The guy came out and replace the control board. The dishwasher now read 199 on all cycles except...
well its not baloney but it is cheesey. normally changing the module is the cure but it has to be programmed correctly. bosch has a recall so check it out and see because the recall is free and the tech is suppose to know how to program it. go to thermedor .com and get the #. i am a old bosch tech.
Mar 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Dishwahser rinse cycle running for hours
Do you have high temp rinse or sanitize selected? This will pause the timer during the final rinse cycle to heat the water. The sensor might be bad. Try the quick cycle, I don't think this heats the water.
Jun 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Bosch 24 in. SHU43 Built-in Dishwasher Logo
451 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
