Question about JBL PSW1000 Speaker
Jbl psw1000 no power
Led wont light, sub wont work. Replaced internal fuse...whats the next most likely component to test/replace ?
  • 70 Answers
Have you checked all fuses. There might be 2 - one for the input and one specifically for the amp section...
Check to see if the speaker is fried. Remove the grill then place your fingers as evenly as you can aa couple of inches away from the cone. Press gently and listen. There should be no scrating sounds at all. If you hear this, first try repositioning your fingers. If it persists your speaker is fried. This is caused by a few reasons. Amp failed and took speaker with it. Or a large signal was inputted which causes the amp to hold its max power for a longer period of time (amplified signal is no longer a sine wave but a sqare wave).
Otherwise, unless you know what you are doing with AC (house power) I don't suggest you go poking around-you need at least a volt meter to start testing
Posted on Dec 22, 2007
I have a JBL S120PII sub that stopped working. All I get is the red and green light flashing on top. Is this indicative of a specific issue?
Check and replace the power output MOSFETs [at the power amplifier circuit]. A damaged MOSFET can cause this continuous LED blinks. It is important to replace all the 4 MOSFETs at one time. Also, check for any further damaged to any other components too have occurred. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 09, 2016 | JBL Audio Players & Recorders
No Power
if u change the fuse inside the actual sub shud power up ok
Feb 26, 2009 | Sunfire True Subwoofer Mark IV Subwoofer
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Is there a replacement amp for my jbl SCS180.6S subwoofer? I tested the speaker and it's fine. I also tested the output from the stereo and it is also fine. When the sub is turned on, there is a b
No you can't! I should contact JBL for the location of the part. Transformers are safety parts and should only be replaced by the same part or those approved for use by the maker of the unit.
Dec 20, 2012 | JBL Audio Players & Recorders
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Continous low level pulsing but no Base Response from JBL PSW1000
There is a huge discussion among audio enthusiast regarding subwoofer output and how you should connect your sub to your system. If sub preout is turned and on your amp/receiver and you are able to adjust the crossover frequency adjust your crossover frequency to highest setting, higher HZ number, so you don't double low pass filter your signal too much. If you can adjust crossover frequency on your receiver and your sub allows separate connection to by pass it's filter, use that instead.
There is a great article on Polk Audio website regarding Home Theater setup. You can use it as reference and tweak it to your taste.
Aug 18, 2009 | JBL PSW1000 Speaker
Sub is blowing fuses!! :(
The issue is most likely a short in the amp internal circutry where power is essentially flowing without resistance acrosss the short. You may or may not have sound or crackling noise as it depends on where the short is.
If you are electronically inclined, I suggest the folliowing:
- disconnect all power and open the amp up
- look for any burn marks around the circut board and parts.
- first focus in on the area where the power comes in - see if any diodes (black cylinders with stripes on them) are burnt / cracked
- next have a look at all the MOSFETS. These should be 3-legged components and will likely be mounted to the shell or heatsink. Look for any burn marks or cracks on these.
- also look for any wire or component that may be shorting other components. Generally all wires should have shielding and all components should be soldered firmly. Anything crossing other components could be a problem.
If you find any burnt/cracked components, they will need to be replaced.
Here is a sample image showing the MOSFET chips to the top and bottom on the aluminum rail.
Apr 16, 2009 | Infinity BASSLINK Car Subwoofer
Digital picture frame wont power back up
Test the power adapter. If the light is flashing, it may not be getting the 12 volts that it needs. You can test it w/ a voltage tester or if you don't have one, take it to Radio Shack and they can test it. If it's dead, or short, replace it and then the frame will work again.
Dec 15, 2008 | SmartParts SP15MW (092566981886) Digital...
PB10 Loud Hum and Crackle- LED Lights mixed Red/Green
Hello, Jesse. I doubt I can help, but there is at least one SIMPLE thing you can try - with maybe a 10% chance it wil return your unit to normal: Unplug the unit for 30 seconds, then plug it back in to a DIFFERENT outlet. Oh, yes - there are NO fuses or other "reset" devices. I'm sorry I couldn't offer you more help.
Jul 25, 2007 | JBL PB10 Subwoofer
416 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
