Question about Woods Hardware & Accessories
Can't get my Woods Model 59018 digital timer to work
I followed the wiring directions to install my woods Model 59018 digital timer. I connected the red and white wires to the common and the black wire to the hot. My outdoor lights begin to flash on and off. When I disconnected the red wire from the white and common wires there is no flashing of the lights but there also are no lights coming on at all. I turned on the power by pushing the little door until the display said on. But no lights came on. What could I be doing wrong. My other unit was an Intermatic and there were just two wires to connect and it worked perfectly for years. Help me out here so I don't have to return it to the store.
Thanks ......Rick Nasello
rnasello@sbcglobal.net
I have same problem and called the manufacturer. They told me they are supposed to help and that these need to be installed by an electrician.
Glad I bought mine at a Menard's which is targeted to the general market.
I don't want to support a company that says things like that to their customers so I am bringing mine back.
Posted on Oct 13, 2009
  • trader_perso Oct 13, 2009
    Oh in previous solution I meant to say "aren't supposed to help". Now the sentence should make more sense
On my third timer - two GE now the Woods one. The lights turn on and off manually but the timer does not work. the wheel/timer does not turn!! how frustrating. I have switched wires etc as they told me on the phone, come on! I should not have to call an electrician. I wish my old Intermatic one did not break! ugh
Posted on Nov 08, 2011
I am on my second Woods timer. The connections are all correct as I am replacing an older timer, but it will not turn the lights on at all. neither with the timer or manual switch. I'v tried changing the connections and nothing works. The first one didn't work either... Luckily I also bought it at Menards and I will return it.
Posted on Mar 13, 2010
  • D FIXR Dec 04, 2010
    ALWAYS TURN OFF POWER BEFORE CONTINUING;
    Make sure you are wired correctly. LINE (in) is power from breaker or power source. LOAD (out) is power to appliance) Lights or fan.
    On the bottom center is the timer on/off switch which needs to be in the timer on position. (pushed to the right) On each side of this are manual override buttons which override the preset time. The timer switch has to be in the on mode to transfer power to the load side of the switch. ( whatever you want to turn on.) Push in for once for on or twice to turn off.
Lights blink when in manual mode
If this is new installation, then Timer is wired wrong:
If timer worked before, then it has gone bad, buy anotyher timer
Copy following links to identify type of timer, single-pole, 3-way etc:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
hh
Sep 24, 2013 | Woods InWall 7 Day Digital Programmable...
I just installed a Woods Digital In-wall Timer Model #59018. When I switch the power and manually turn the power on, the lights rapidly flash on and off. This is a three-way outlet and I have red, black...
3-way outlet or 3-way switch?
Woods 59018 only replaces single-pole switch, and does not work for 3-way application. Often connecting timer wrong will cause lights to blink. No harm done to lights, timer or wiring.
There are several timers that work with 3-way. In each case the timer replaces 1 switch and other 3-way switch must be rewired.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
http://waterheatertimer.org/ST01C-program.html#3-way
Gene
Aug 03, 2013 | Hardware & Accessories
Lights are blinking after setting up the timer
You connected white wire and red wire together.
No harm done.
ez to fix.
Woods 59018 is single pole timer.
Copy following link to see step-step for wiring single-pole timer:
Add a comment as needed
Jul 08, 2013 | Coleman Cable Woods 59018 InWall 7Day...
Describe model 59017/ how to program. Does it work with halogen bulbs?
Question is not 100% clear.
1) Question posted under Woods 59018
59018 is programmable digital timer which does not show 'electronic ballast' or 'halogen' as a load capability.
http://waterheatertimer.org/pdf/59018-sell-sheet.pdf
2) Question asks about Woods 59017
59017 is 24-hour analog timer which will work for all loads including CFL and halogen loads
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
3) Add a comment for more help.
For example Aube programmable timers will work with CFL and halogen
http://waterheatertimer.org/Aube-timers-and-manuals.html
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
I have the Woods 59018 In-Wall 7-Day Digital Timer, and am having trouble installing it. I am replacing an IntermaticModel EJ251 timer that only connects using two black wires in the junction box (as...
Open following link to identify timer, read wiring instructions, and download on-line manual:
How to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
After installing the light blinks when on. Tried reversing wires and this did not work.
You posted under Woods 59018 timer.
1) This timer is made to replace single pole switch only.
2) If lights are blinking, then wiring is suspect. Probably the red and white are connected together.
Open following link to confirm this is your timer and read ez wiring steps and see on-line manual.
The wiring steps work for all brands of in-wall 7-day timer except those timers that can be used for 3-way switching.
3) Page also lists timers that can be used for 3-way switching, for example in hallway where 2 different switches control same light. List of timers has links to each timer and manual.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 02, 2011 | Coleman Cable Woods 59018 InWall 7Day...
Wood timer 59108. We do not have manual and don't know how it works.
I don't have 59108 timer listed for Woods.
1) Woods makes 59018 White-colored in-wall digital 7-day timer
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
2) Photo that you posted question with is Woods outdoor 59204 or Woods outdoor 49109
These timers have a dial on face of timer.
Rotate dial until current time lines up with arrowhead.
Segments located around edge of dial are used to set times.
Move segments up-down (49109) or in-out (59204) to set on-off times
Move override dial (49109) or override switch (59204) to Timer, or timer ON so timer will follow programming
If above is not your timer, link below shows all Woods timers and manuals to help identify your timer
Add a comment any time
Dec 10, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
Woods 59203 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If your timer is not listed, add a comment with description of timer
Nov 15, 2010 | Woods InWall 7 Day Digital Programmable...
Hardware & Accessories Logo
1,913 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
