Question about Hobart D300 Stand Mixer
Motor turns and the top shaft turns as does the grinder attachement but the bottom shaft does not turn. The grease is clean (no metal filings) I can't figure out how to remove the main shaft to see were it connects to to the beater shaft.
  • 110 Answers
Sounds like you sheared the key on the on the ptanetary to main shaft. remove planetary of mixer. you will see how main shaft is keyed to planetary. replace key reassemble , and you will be mixing agian, dont forget to vote, thanks, monomoy
Posted on Jan 10, 2010
I have a kitchen aid 5 at. Mixer when I use my grinder attachment I notice oil/ grease on shaft what is that caused from
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
Dec 15, 2014 | Food Mixers
I need a repair manual and parts manual
Once you're familiar with it, the A200 is OK to work on. Just pay close attention to the sequence in which the gears are removed and lay them out on a table in that sequence. You'd need to remove most of the gears from the center planetary shaft, which requires removal of the shift lever (right side, 4 screws). You shouldn't need to remove the planetary (lower end that holds the attachments and rotates). Eventually you'll be able to remove the smaller shafts as assemblies and replace the brass worm gear.
You'll want to scoop out the grease with brass shavings in it (replace all the grease to be thorough, especially if it has broken down and is very runny or very thick (the grease should be a little bit thinner than the consistency of peanut butter), spin the removed bearings by hand and listen for rough operation (particularly the smaller bearings on the upper end of the two small shafts (bearings in the upper bearing cover). Also check to see that the two brass bushings, which reside in two of the gears removed from the center planetary shaft, spin freely BOTH on the planetary shaft AND in the gear they reside in (if not, one of your speeds probably won't work).
For an experienced technician, the job would take approximately 1-1.5 hours unless the old grease is all cleaned out thoroughly to replace with all new grease (thorough cleaning requires the removal of planetary and planetary shaft), and thorough cleaning can be a time consuming process. Then you might get closer to 2.5 hours.
May 07, 2010 | Hobart A200 Stand Mixer
Loose gear
Lock out-Tagout the machine. Remove the top cover, hold the beater shaft while removing the center shaft nut. Then remove the 4 bolts and and hardware on top of the first(worm) shaft and the second(clutch)shaft. you can gently tap the top cover up with a cold chisel on the upper parts of the housing. It's just a friction fit , aligned on two dowels. Once the cover is off, scoop out the grease, remove the side panel and selector assembly. Try and lift all of the first gear assembly together. the newer ones have a series of rollers and springs, which can be easily reassembled, if you see which way everything was. As you rmove parts, lay them on a clean surface in a row in the position they came out. The selector sleeve is marked TOP, but looking at the 4 drive teeth each side, you will see how it drives 2nd and 3rd gears. The clutch and worm shafts lift out together from slip fit bearings in the housing base.
When reassembling, coat everything with new grease, and run before loading all the grease. If you need to remove anything , you won't be up to your wrists in grease doing it. Once all is good, load the grease in the top hole nearest the motor with it running. The gears will feed the grease as you load the 35 OZ.
If you removed the planetary to remove the center shaft, don't tighten the half nut tight. back it off a half turn and lock it with the acorn nut. Otherwise you will loose first gear from pinch friction.
Sep 14, 2009 | Hobart A200 Stand Mixer
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
May 12, 2009 | Sunbeam 2485 MixMaster Series Hand Mixer
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Taking the top off my kitchenaid mixer
Remove the back housing by removing one screw and liftingand pulling rearward.
Remove two screws holding the metalic edge trim. This uncovers the seam. Screws are on the back.
Remove four visible screws from the bottom of the head around and near the pillar.
Now gently using a screw driver, push the metallic ring on the mixing head down and off.
This uncovers five more screws about the mixing head. Remove them.
Using a very small screw driver or punch, puch the pin out of the mixing head shaft.
Remove the mixing head housing.
Lift up on the motor housing to remove it.
The motor/gear housing is the top protion of the mixer. Its loaded with grease so do this over a covered countertop or some place easy to clean. The grease won't run, but it can fall out in gobs.
Make sure all sealing surfaces are clean, especially the gasket around the gears. This will insure a good seal. No gear grease in your famous cookies!
Reinstall in reverse.
Feb 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
Slips in all gears
you have no speed 1,2,3 right?first thing to do is drop the planetary (this is the bottom with the beater shaft)undo the bolt and it will drop down.you will see 1 gear,that gear should not spin without the shaft spinning too.if it does you have a sheared key on the gear.if you have access to the transmission check the worm gear attached to the motor it has a roll pin through it make sure its not sheared.then look at the top left gear assembly and check for sheared (broken)keys.clean up all the parts,if you dont you could miss something.let me know.
Aug 22, 2007 | Hobart D300-6036 Mixer
Hobart D300 Stand Mixer Logo
125 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
