Question about Nokia 3110 Cellular Phone
Cannot power up a nokia 3110 classic. full charged battery
Have checked the battery on a 3110 classic and has 3.8 volts. power switch does not turn on the phone and when connecting charger it does not indicate receiving a current charge on the screen. I have placed the battery in another phone and proved that the battery works. can you advised a reset method without the power on??
Nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts.
Please solve my problem.
Posted on Dec 12, 2009
  • mdsaoodalam Dec 12, 2009
    nokia 3110 classic.on the time of update software USB Data cable have been disconnected. and that time mobile was automatically off And after its not starts.
Nokia 3110c mobile restriction code
Hi, You can get the restriction code for a Nokia 3110 Classic from www.classicunlocking.com/nokia-3110-classic/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 3110 CLASSIC
1 - Switch on your Nokia 3110 CLASSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110 CLASSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3110 CLASSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 CLASSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3110 CLASSIC
Nov 03, 2012 | Nokia 3110 Cellular Phone
Enter restriction code of nokia 3110c IMEI356418029757543
Hi, You can get the restriction code for a Nokia 3110C from www.prounlocking.com/nokia-3110-classic/rs16wp9/ at low cost.
UNLOCKING STEPS FOR A NOKIA 3110 CLASSIC
Oct 31, 2012 | Nokia 3110 Cellular Phone
My Nokia 3110C is requesting for a RESTRICTED CODE. It says that the phone is restricted. Could you Please Help Me???
Oct 30, 2012 | Cell Phones
My nokia 3110 classic is dead , how will on
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
You can also try out another battery..ok
GOOD LUCK.
May 28, 2011 | Nokia 3110 Cellular Phone
My nokia 3110 dead not power
FIRST CHANGE UR BATTERY WITH FULL VOLTAGE
VOLTAGE 3.60 - 4.20V.
CHK BATTERY CONNECTOR
IF IT DESOLD
SO SOLD{RESOLD}IT
CHK SHORTING ON BATTERY CONNECTOR ON BUZZER RANGE IN MULTIMETER
CHECK CHARGING IN UR CELL
CHK ON OFF SWITCH VOLTSGE 2.80V
CHK ON SOFTWARE OR FLASH UR PHONE
SAME IT DEAD
SOIT HARDWARE FAULT
CHK ALL POWER SUPPLY
IDRISH 911
Oct 30, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c is not switching on properly it auto matically switching off within 2-3 second yesterday i had download some wallpapers from internet it might be due to virus so what i should do
That is the your battery charge problem. your cell phone battery doesn't give sufficient back up to your cell phone. first charge your battery full charge then try. otherwise change your battery.
Aug 22, 2010 | Nokia 3110 Cellular Phone
My nokia phone 3110 classic is automatically switchoff within few second?why?what is solution of this?
Replace the battery. And make sure you charge ti full than drain it completely 3 times it will last forever!
Nov 19, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
459 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
