Question about GE Hotpoint® HTR17BBSL Top Freezer Refrigerator
Mr. hello i have noticed the temperature hits nearly 60 degrees F in the top freezer during defrost cycle. is this too warm? to see how long and warm it gets i put an ice cube in a cup, after a couple of days the ice cube partially melted and then refroze as seen by its no longer being cubed shaped. when the freezer is operating the temperature gets down to zero degrees F. is the defrost cycle increasing the temperature too high for too long a time? what is the maximum temperature i should expect?
  • GE Master
  • 1,606 Answers
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Posted on Oct 03, 2009
Freezer works refrigerator portion does nt
If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Regards.
Aug 15, 2011 | Refrigerators
Refrigerator is not cold. Freezer works OK
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
Good luck.
Jul 11, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hi, my refrig is JennAir JFC2087HRS, top refrigirator is not cool and there are lots of frosts at the back of bottom freezer, how can I deal with it ? short-term by unplug and open the freezer to...
If refrigerator is not cooling, it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
Good luck.
Apr 07, 2011 | Jenn-Air JFC2087HRS Side by Side...
Fridge freezer - freezer working but fridge not. red warm light is on
Good luck.
Mar 30, 2011 | Refrigerators
Freezer works but not refrigerater why?
Good luck.
Mar 23, 2011 | GE Refrigerators
Freezer cold but refrigerator is not
Good luck.
Mar 22, 2011 | GE Profile Stainless Bottom-Freezer...
My GE profile side by side frig goes into defrost mode more often, every 1-2 days. Temps go up to 46 degrees for frig and 8 degrees for freezer. It doesn't take too long before it cools back down. Is...
. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Mar 08, 2011 | GE Refrigerators
Cold side gets very warm too when hot side heater is
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
Dec 26, 2010 | Refrigerators
My ge side by side refrig freezer gets on the auto defrost cycle in the freezer and then all the ice cubes in the ice maker freeze into a solid ball of ice. The ice maker does not work after that. Why does...
Nov 02, 2010 | GE Refrigerators
The freezer half stopped working Sunday morning, and the items on the top were thawed more then items on the bottom. We left it a couple hours and it started working again.
Sounds like your defrost thermostat is not working.
Oct 11, 2010 | Kenmore 57029 Side by Side Refrigerator
GE Hotpoint® HTR17BBSL Top Freezer Refrigerator Logo
132 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
