Question about Olympus Camedia C-350 Digital Camera
My camera wants me to format my card but i will lose all images
I have a hp photosmart camera and i turned it on and the card read that it is unreadable replace card or press OK to format card. but if i format the card i will lose all saved images
When i turn my camera on it says i need to format the SD card so i hit okay then it deletes all my pictures and says unable to format
The contacts on the card are dirty. Insert and remove the card several times and try it again. You can recover pictures off an erased card. Google SD card file recovery software.
Apr 17, 2016 | HP Photosmart 735 Digital Camera
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
When I insert my SD memory card into my photosmart 420 it says card access error
Hi there
I dont think your printrt is made to read SD cards the only way it see the SD cards if they are in the camera and the camera lead into the USB inlet on the printer.
Printer Specifications
Category Specifications
Connectivity USB 2.0 full-speed
PictBridge
: Using the front camera port
Bluetooth: Microsoft Windows XP Home and
XP Professional
Image File Formats JPEG Baseline
Margins Top 0.0 mm (0.0 inch) ; Bottom 0.0 mm (0.0 inch);
Left/right 0.0 mm (0.0 inch)
Media Sizes Photo paper 10 x 15 cm (4 x 6 inch)
HP
Feb 28, 2010 | HP PhotoSmart 420 InkJet Printer
My memory card worked
Can you put the card in your pc and format it? You may have to erase the pics you have before formating it but usually it erases them for you while formatting.
Aug 25, 2009 | HP Photosmart 320 Digital Camera
Card is unreadable
Take out the card and transfer the photos to the computer. After you verify that your photos are safely on the computer, reinsert your card in the camera and proceed with the formating.
Aug 03, 2009 | HP Photosmart R707 Digital Camera
Camera will not read card.
Please format the card on your computer and try it later in the camera
May 16, 2009 | HP Photosmart R707 Digital Camera
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Menory card unreadable etc.
ok check the card slot for the memory card the pins are bent... for shore
Sep 03, 2008 | HP Photosmart R707 Digital Camera
Won't read sd card - says card not suppoorted
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
May 21, 2007 | HP Photosmart M417 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
168 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
