Question about Maytag Dryers
I have a Maytag DE303. The dryer buzzes when the timed cycle is done, but the buzzer will not cut off unless you open the door. When I disconnect the buzzer, the dryer will not work at all. So either the dryer is on or the door is open. What needs to be done?
mikedurland
  • 481 Answers
SOURCE: Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Posted on Jun 28, 2008
http://www.youtube.com/watch?v=
Posted on Jun 30, 2008
  • 686 Answers
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Posted on Feb 18, 2009
  • 1891 Answers
SOURCE: how do i OPEN a maytag model DE303 dryer?
remove the two screws down by your toes . in front panel //pull out at bottom till panel is 45 deg . and the two top cli[ps will release . carefull to not brake the door & wires . remove wires and set side . hey your in .. now what do you want to do .. feed back pls .. mm
Posted on Dec 17, 2009
cool78259
  • 228 Answers
SOURCE: Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Posted on Jul 25, 2010
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
We have a white-westinghouse dryer. serials # wde446jbs1. in the off position the buzzer constantly buzzes, in any type of run position there is a loud humming or muffled buzz. only when the door is...
ok, there is a chance that a wire from the door switch has come loose when she close the door. unplug dryer,take front panel off and check wires at door switch. you may have 3 wires, one on one side and 2 on the other. the single wire is the common, on the other side one is for the dryer operation the other for the end of cycle which can be use for a buzzer or cavity light.
Feb 09, 2011 | Dryers
I have a Maytag dryer (Model MDE2600)and the buzzer will not go off unless the door is opened. Buzzer begins when door is closed.
Hi
Buzzer comes on because the control senses that the door is not closed and won't start the cycle. This issue is caused by door switch-latch assembly (part#6 and part#9 in this diagram) that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | Maytag Dryers
We have a 80 series elec. dryer, today when the end of cycle buzzer sounded, when door was closed again...buzzer continues to buzz. I can't find a part number, if the end of cycle buzzer needs replacing. ...
Push the timer to a definate off position. Close the door. If it buzzes then more than likely you are getting power from the timer which could mean short in the timer. If you have the model # the parts places can easily find your parts.
Dec 28, 2010 | Kenmore 800 6983 Electric Dryer
How do i OPEN a maytag model DE303 dryer? Not just the door (duh), but the actual dryer itself, for repairs...
Dec 17, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
I want to turn off or disconnect the "finished cycle Buzzer".
That buzzer can easily be defeated so that baby won't wake up or paw paw! LOL! It is located near the control up top. A small black box with 2 wires going to it.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
151 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
