Question about Adcom GFA-7500 5-Channel Amplifier
Can I connect a 150watt amplifier to a 100watt speaker.
How do you hook speakers up to a mpa-125 100watt pa amplifier
Have you downloaded the manual ?
All explanations are there. Just Google it.
Luck.
Jul 27, 2015 | Audio Players & Recorders
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
Hello, after plugging on Ipod through my preamp hooked through my krell kav 300 integrated amp I heard a super loud noise and lost power. I examined the fuse and it looks fine. What do I do?
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
Apr 17, 2010 | Krell KAV-300i 2-Channel Amplifier
Will a sony xplode 100w amp bridged push a 1600w cab? if not what is the best compatible cabinet wattage reccomedation?
100watt amp and 1600 watt cab?? Your amp will run it but a lot of the dynnamics of the speakers won't be there.
Dec 21, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Not really a problem want to know if I could add a extention speaker to the fender rumble 100 combo it has not ext. speaker out looking to add two 10 inch and if so how?
Hi there. If 10" speakers are 8 or 16 ohm, parallel them. If they are 4 ohm, series them. if "External speaker" output is rated down to 4 ohm. If no external speaker jack, you'll have to tap into existing speaker jack with a "Y". Check the minimum ohm load for the amp.
Thanks
Paul
Jun 03, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Wire house speakers
Two ways--first you can open up the unit and use the exsisting wires from the tvs internal speakers or goto radio shack and ask them for a audio jack splitter,you would than connect the wires from the speaker to the splitter then plug the jack into the audio input on the back of the tv.If your thinking youll get more sound from these speakers by doing this it wont work unless you have a surrond sound system.Only an amplifier can boost the output.
Feb 23, 2008 | Alpine CDA-9815 CD Player
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Adcom GFA-7500 5-Channel Amplifier Logo
85 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
