Question about KitchenAid KGST307 Gas Kitchen Range
Error code f3e0, oven wont turn on, follow instructions to set temp, after hitting start, get 3 beeps.
    President:
  • 1,723 Answers
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Posted on Oct 03, 2009
  • laurie stephens Jun 30, 2013
    replaced the oven temp sensor but still getting the f3e0 code any thoughts?
Error F3E0
next time you see the error codes, write them down. F3E0 is open sensor error . I don't think you have an oven sensor error or a problem with the sensor. When the oven works the temperatures are good so the sensor won't be open. F0E0 is "No Error" and "No Action Required". It sounds like a loose or a bad connection in the control section. There is no connection between the oven door and the control panel. Opening and closing the door to clear error codes or to get the oven to work is jarring the control and the loose or bad connection to the point it makes contact and works. Start with the ribbon connector and remove and reinsert it. You can also use a pencil eraser to gently clean the end of the ribbon connector. Remove and reinstall the wire harness connectors on the boards. Make sure all the pins in the connector are in place and not starting to come out the back of the connector.
Sep 30, 2016 | Ovens
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
Oven beeps and displays F2 or F3?
Hello there:
this error code is telling you that the oven temperature sensor is going haywire and needs to e replaced
Here is the 2 error codes and what they mean and what needs to be checked
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor
Oct 04, 2010 | General Electric Stove/Oven/Range Chrome...
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
My oven wont quit beeping!
if it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Feb 13, 2009 | Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
F3E0
F3 means the oven temp sensor has failed E0 means it failed open If you have a test meter i can tell you the resistance at room temp is 1100ohms. otherwise call for service Hope this helps PLEASE rate my solution Thnks...
Oct 02, 2007 | Whirlpool SF315 Dual Fuel (Electric and...
KitchenAid KGST307 Gas Kitchen Range Logo
764 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
