Question about Craftsman Tools & Hardware - Others
Need a copy of manual for Sears 92570 dovetail jig
2 Suggested Answers
SOURCE: I am looking for an owners manual for a sears 12
http://www.managemyhome.com/
Sears does a horrible job of getting this info out, but this is the website that has all their manuals for Craftsman power tools.
Posted on Jun 28, 2009
Are the 7 degree dovetail bits, that come with the jig, the only size that can be used or can a 9 degree bit be used?
Hi, W/D at your service.
Apparently, there are several types of bits compatible with your model.
Here's a link that gives you a better idea:
http://www.toolup.com/porter-cable_4216_12-deluxe-dovetail-jig-combination-kit.aspx
Best regards, --W/D--
Feb 23, 2011 | Porter Cable Porter-Cable 4216 12" Deluxe...
Where can I purchase an owner's manual for a Craftsman dovetail jig Model # 315-25710 A2044? Virgil
You might check this out, I found it in another forum. It looks like Ryobi made this dovetail jig for Sears.
1-800-525-2579 is their customer service line. I would ask for Ryobi Tech Services.
Nov 22, 2010 | Craftsman Saws
I need an instructional manual for Dovetailing Jig by Craftsmand Model D>09 MY>2570
try this site: www.managemyhome.com
or
http://www.searspartsdirect.com
Nov 30, 2009 | Craftsman Saws
I need operating instructions
Here is a direct link to your owners manual. You can print it if you want a hard copy or you can order one from porter cable.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65507&typeId=14816&documentId=30657
Hope this helps.
Richard
Mar 09, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Dovetail leave a 'light gap'
This may not be related to your jig. It may be movement in the vertical axis resulting from:
  1. The router bearings being worn allowing the bit to move up and down.
  2. The router bearings worn allowing the spindle to deflect side to side which changes the bit height slightly (cuts on the edges, making the cut a hair deeper).
  3. The router collet or router spindle worn, allowing the bit to move during cuts.
  4. The jig guide plate deflecting or no longer flat.
  5. Excess vibration in the router causing the wood to move in the jig.
To check the bearings; try routing the cut with a straight bit first to clear the wood for the dovetail bit. Then cut with the dovetail bit (a new one preferably) using very light feed pressure. Is the joint tighter? If so then the bearings are worn. Have the router serviced or replace it.
Check the end-play by pulling on the router shaft, does it wiggle slightly in and out? If so this is your problem. Have the router serviced or replace it.
Be sure the wood is flat and the faces planed parallel, if they aren't the dovetail line will be straight but when you assemble there will be slight end gaps in sections of the dovetail.
Feb 23, 2009 | Porter Cable Porter-Cable 4216 12" Deluxe...
Need a manual for PC omni jig- original model
You will need your model #
Here is where to get your manual
Good luck and let me know if I helped
Jan 06, 2009 | Porter Cable 55160 16 Inch Omnijig...
Tools & Hardware - Others Logo
709 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
