Ip address on my computer?
Dear Sir
I cannot connect to the internet as it says can not to server.i have a strong signal from the wireless network when i scan .i do not have a ip address and do not know how to fix this problem
  • chris1953 Dec 21, 2007
    hi ,
    still not picking the ip address, saying not connecting to internal or external command
    thanks
    Aditi,
    I did what you said,what i am getting is :ethernet adapter local area connected:
    media state............disconnected
    wireless network connected:..............disconnected
    does not recognise ping 64.233............as an internal or enternal or operable programe or batch file.
    the system was working fine, until I changed the WEP setting on the airport express.i have disconnected the airport express
    on the wireless survey the wireless card is picking up the router fine.
    The system is on a linksys and the other computer is working fine.
    Problem Solver:
  • 9 Answers
Try this :
Go to Start -> Run -> Type 'cmd' (without the quotes)
In the command prompt window - type - ipconfig
If you do not see any ip address like "169.254....."
Type ipconfig /release (hit enter)
Type ipconfig /renew (hit enter)
Type ping 64.233.169.103
See what response do you get. If this says Sent = 4 ; Received = 4,
Go to IE and try opening a webpage.
If this says, Sent = 4 ; Received = 0
Tell me what ISP do you have?
How are you connected?
Have you ever been able to connect to this network before?
Do let me know what happens...
Thanks & Good Luck
Aditi
Posted on Dec 21, 2007
  • Aditi Jain Dec 21, 2007
    Chris, Can you please elaborate the problem. and give some more details about it.
    Alright. You said you have strong wireless signals.
    Do this -> Go to Network Connections . Right Click on Wireless Network Connection and click on View available wireless connections.
    Now check if you see your wireless network in the list. If you do, connect to it. and then try opening a site.
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Computers & Internet
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Televison & Video Logo
1,287 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
