My hp 1100 printer drag many papers in same time K so i change the piece in the printer to solve this problem , but unfortunately the printer completely stop , when i power on the engine works good , put the LEDs did not work , and test page can not print
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
have u changed the cartridge it self u are buying a new one right no refilled stuff if thats the case drum cartridge and the thirs thing is may be piece of paper is stuck inside which got wet with the ink every time u try to print it gives u lines on print pls try this and tell me or tell me the status of ur cartridge and drum
Firstly PRESS THE BIG BUTTON Secondly if this doesn't work remove toner cartridge and look inside there maybe a piece of paper in there. Thirdly Remove paper look down the paper feed entrance check there is no paper there. Finally Replace toner cartridge.
