Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Wont **** dirty water back out of carpet and it has nothing to do with the lid not being on properly, just no suction...
    Scholar:
  • 190 Answers
Please check and see if the round gasket is on the round vacuum pipe under the hood, that contacts the dirty water tank. It should be a soft seal that touches the round open cylinder on the base of the dirty water tank.
Posted on Oct 03, 2009
Hoover steam vac deep cleaner not ucking up
Hi! If your cleaner is not picking up this could mean that something is not sealed off properly. Try these brief trouble-shooting steps to restore suction to your SteamVac.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Give it a try! The suction should be restored. Hope this helps!
Aug 26, 2014 | Hoover Vacuums
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
Why is the "dirty water" reservoir still empty after I cleaned the carpet?
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 09, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My bissell will not suction water from the carpet
Please check the following:
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
If you continue to experience low suction, please contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The suction is not working. we have tried all the
check RECOVERY TANK LID and DUCT
May be the duct is off the hook
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac
OKay! I've figured it out! After making sure I had the cleaning solution container connected properly, the "lint filter" thingy clear, the attachment plug thingy unplugged, the filter in it's proper position, (about a cm down from the seal), and the seal on the filter was all good, etc etc etc, the brushes in properly...I was about to drive over this steam cleaner with my car!
After taking a break and going back to it, I discovered that I didn't have the lid to my dirty water tank (or air tank, as I was starting to call it) properly closed. There are two lips that you have to make sure the lid "hinges" from, and THEN snap the lid shut. This made a seal that allowed this steam cleaner to **** up all kinds of gooey gunk from my carpets! The brushes work, the suction works, it's a FABULOUS machine! It doesn't get any louder when it's sucking up water, either.
All this AND I had the instructions! Go figure!
Jul 12, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover spin vac wont **** up the dirty water!
Check the lid on the dirty water tank. This is a very common problem. If the lid is not engaged in the tabs of the tank, the lid will not sit down properly and all the suction will leak out between the lid and tank.
Mar 25, 2008 | Vacuums
No suction
I finally got my steamvac F5914-900 suction to work after I read someone review about it on amazon. Here is what that person suggested for suction problem and to my surprise it worked.
1. Any time you aren't getting suction, the first thing to do is check the dirty water bin. I re-seated the thing about ten times this morning, trying to figure out why suction on the unit had ceased. (The dirty water tank was bone dry.) I was frustrated because I was absolutely sure everything was seated properly, but was still getting no suction.
Finally, I pushed on the lid from the _sides_ rather than the back or front while attaching it to the tank, and it seated a little bit differently. Suction was restored!
2. To clean out the suction area, pour some hot water on a tile floor (NOT wood) and **** it up. Repeat until everything is flowing smoothly. Sometimes, reduced or minimal suction is due to gnarly clogs. Again, though, if you're getting NO suction, the culprit is probably the dirty water bin's lid.
I hope this helps.
Mar 23, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
