Question about Whirlpool Duet GHW9150P Front Load Washer
Was does F H code mean on washer
When washing a load I get a message of F H on my machine. Any ideas?
    President:
  • 1,776 Answers
This code typically indicates a fill problem. Much of the diagnosis of a potential problem hinges on whether there is any water getting to the machine. If there is no water getting to machine, then check the water inlet valve. Unplug the machine, turn off the water, and check the small metal screens inside the opening on the valve. Make sure they are clear of rust or debris and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid.
If there is water reaching the machine, then look at a faulty water level switch. Make sure the plastic tube attached to the switch is clear of any obstruction or damage and the switch can be tested in the same manner as the solenoids on the inlet valve. This can also be caused by a defective flow meter.
These are a some of the things to consider. If no water is detected filling the machine within 30 seconds, then the valves will be shut off and the code displayed OR if the water has turned on and after 8 minutes the flowmeter has detected 10.5 gallons of water passing through it, but has not detected a pressure switch trip, then the code will be displayed. These are the parameters that will cause this code to be displayed. Rather convoluted and I hope you are able to follow my ramblings. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 03, 2009
    Scholar:
  • 31 Answers
The FH code on your washer indicates that the there is no water detected entering the machine or the pressure switch has been tripped.
If there is no water entering the machine:
#1 Check to see if both taps are open
#2 Check for kinked inlet hoses or if the screens are plugged in the inlet valve.
If there is water entering the machine what this means is that the flow meter has detected that 10.5 gallons have been put into tub.
#1 Check to make sure you don't have a siphon issue. Check your drain hose and ensure it's not at the bottom of the stand pipe.
If you have tried all these, the next step would be to call for a service technician because electrical test will have to be performed on other components.
Good luck. Please let me know if this helps!
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
There is an error message that says F
If the machine is "frozen" you should be able to fix that by either pressing/holding down the reset/cancel/stop button. Failing that, unplug it for a little while. I believe error code F is related to water filling problems. The machine is indicating that it's having trouble filling with water like it was expecting. This means one of the water lines to the washer may be turned off or connected improperly. If the water supply is ok, that would indicate that the machine is having trouble with its internal sensors. It will need to be serviced.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Message LD on washer
L D code meanning long drain. lint causing the problem . and restricting the pump inlet .. remove pump and clean out .. ****
Dec 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio Washer Error message code F1
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
