Question about Cameras
I can't load my movie fromm my sdr sw20 onto imac? help? It just tells me to please connect ac adaptor
Why does my panasonic video camera not allow me to download into my imac. It tells me to plug in my ac adaptor??
Such data transfer requires the ac adapter to be plugged-in as it is safer. Just try with the ac adapter plugged-in
Aug 17, 2010 | Panasonic SDR-H40 HDD Camcorder
Connecting Panasonic SDR-H80 video to PC / Mac without AC lead?
hi, you can record on a SD card that you can then remove and read through an SD card Reader (a usb key where you slip the card and pof! you have it). For the Mac/ Pc/ Power adaptor I have the same problems. tell me if your quest for knowledge was fruitfull anywhere else.
W
Jan 24, 2010 | Panasonic Video Cameras
Message on camcorder when trying to download "Please connect ac adaptor" if i flick to still pics they download no problem.
its becouse the camera knows your on battery power and to save your dater it plays safe and wonts more power that cant run out half way in the down load
Nov 15, 2009 | Panasonic SDR-H40 HDD Camcorder
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
I cant upload my videos from my SDR-H40 HDD camera onto my pc
hey bro u know all the cables n the battery charger? u take them ntake the battery outta the camera, put it on the charge, put the battery that connects by cable to the charge in the camera, then plug it all in. should work for ya
Jun 22, 2009 | Panasonic SDR-H40 HDD Camcorder
Panasonic sdr-h40p cannot connect to my pc
hi all, i had exactly the same problem and finally managed to sort it out, here to share with u all. The AC adapter is the one looks like a battery cable which comes with the camcorder. You have to remove the battery first, and plug the AC adapter into the place where the battery was, then connect the other end to the battery charger. Now you can select the PC connect option and transfer your videos. Hope it helps. =)
Aug 25, 2008 | Panasonic PV-GS500 Camcorder
Cameras Logo
111 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
