Could mic be attached along with the Pc sound card
In advanced its not work the michrofone , its not see on the playback,what its solution?i have a xonar D1 system sp 3
Posted on Nov 12, 2009
    Genius:
  • 1,601 Answers
Most sound cards have a port for you to use a microphone.
Posted on Dec 21, 2007
Inbuilt Mic not working Medion MD96350
I Suggest that you scan your computer with RadarSync so that you will know which drivers are outdated since you have two possible problems here.
1. Hardware - sound card not attached to the computer properly.
2. Software - outdated driver
I suggest that you update the drivers so that you can cover the software side of it. If it won't get fixed, then you would need to contact a technician to get your computer serviced.
David
Apr 06, 2013 | Computers & Internet
My mike dosn't work
Since you know your mouthpiece is not working.
I strongly advice you use a earpiece and it will serve as both mike and speaker for your phone.
But if you want to fix the mic of your phone,
These are the processes to follow to fix your mic;
  1. Get the appropriate screwdriver (Phillips screwdriver, plastic tool such as a guitar plectrum or credit card.),
  2. Remove your back cover, battery, sim and memory card. Remove the four screws you can see.
  3. Peel back the sticker. You may need something with a thin, sharp point to peel the sticker back with. Two rubber stoppers need to be levered out to reveal two more screws that must be removed.
  4. Run your plastic tool along the join of the battery compartment to separate the phone into two halves.
  5. Next you need to disconnect the ribbon by the right. This attaches like a plug and socket. Simply lift the connector up, away from the circuit board to unplug it.
  6. Remove the screw by the left.
  7. You can now lift the green circuit board away from the phone. A little force is required.
  8. You should now have the circuit board removed. Note that a ribbon, will have to be disconnected when you removed the circuit board. Again, this attaches like a plug and socket.
  9. On the circuit board, you will see the mic on it, get a replacement mic, disconnect the old mic and fix the new mic.
  10. Then reverse the process to reassemble the phone back together.
Take care
Jun 21, 2010 | Samsung J700 Cellular Phone
Creative soundcard sound blaste rSB1071
the sound goes from the sound out jack on PC to the audio in jack on ur home theater or to the mic in jack/karaoke in jack
Jan 16, 2010 | Compaq Creative Sound Blaster PCI 128...
How to install my microsoft lifecamVX-1000 inorder to chat my friends with web cam?
to chat with ur friends u will need the foll:
WebCam, Mic, and Speakers.
Alss u will need to have either Yahoo Msgr, or MSN Mgr etc
u need to connect the Webcam using the USB port and once the Webcam is detected by your OS (i assume u use Windows) u may have to install the driver for the Webcam(the CD that came along with the Webcam will have the driver)
inster the CD in the CDR/DVD drive and let the machine install the device....once it's doen u r set
Mic and Speakers r normally Plug and Play devices and they just need to be connected to PC/Laptops sound card/Mic ports in you machine and they will automaticaly work.
Dec 09, 2009 | Microsoft LifeCam VX-3000 Web Camera
I have a dell inspiron e1705. i have no sound coming out now. i installed a creative cam and since then i had to plug in the mic for sound to come out. now even with the mic installed there still isnt any...
Check your sound setting - volume out - if mic on turn it off - (gets turned on for testing).
Go to sound settings in Control Panel and check sound card setting for correct sound card output.
ALSO - check that MIC is plugged into MIC and NOT Speaker Out - common error.
Oct 18, 2009 | Dell Inspiron E1705 Notebook
Cracking, skipping, jumping
set the sensitivity of the microphone down or get a new mic.
Sep 03, 2009 | Tascam US-122 Sound Card
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
