Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Just rebuilt a 55 rancher and doesn't like to stay running. Its sounds like it is running out of gas? I replaced the filter, gas line, and gas tank breather but still no luck. I am wondering if the crank case is leaking but see no signs og a leak?
picatudo
  • 239 Answers
SOURCE: Chainsaw is extremely hard to start and won't stay running.
adjust the two little screws on the carburator
Posted on Dec 31, 2008
  • 72 Answers
SOURCE: Husqvarana Rancher 55 , how to clean the exhaust port
Cleaning the exhaust: on the saws I've worked with it was just to loosen two bolts at the front and then the exhaust is off the saw. Clean with brake cleaning fluid and blow with compressed air, let it dry before assembling. Don't forget to clean the fine mesh at the output side underneath the lid if present (i.e the spark arrestor).
Make sure to have your carb adjusted properly afterwards.
Posted on May 24, 2009
  • 4088 Answers
SOURCE: Husky 55 rancher - I rebuilt this saw but now it
Check for plugged fuel filter and muffler. Check the fuel lines for decay or damage. Did you service the carburetor? Make sure the lower chamber diaphragm is not hard or cracked. Did you change the two jet settings? Put some fuel mix into the plug hole and pull it through--you should get a pop or two. If ok, then concentrate on the fuel problem. If no spark at the plug, check the ignition module gap to the flywheel magnets using a thin business card for a gauge. Hope this helps!
Posted on Jun 17, 2010
  • 4088 Answers
SOURCE: chain oil leaks out quickly
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Posted on Jul 11, 2010
  • 2239 Answers
SOURCE: how do i replace the fuel line on the rancher #55.
The fuel hose is just pulled into the tank ( interference fit ) take a new hose, cut one end into a point, push this into the top of the tank as far as you can, now grab the end through the the fuel filler holr and pull the hose on through, pull enought through to allow the filter to move in the tak.
Posted on Apr 14, 2011
Testimonial: "this was a great answer to my question. it made my problem an easy fix thanks"
55 rancher fuel line
I put a stiff wire inside my gas line and put a little oil on teh grommet,
Feb 01, 2012 | Husqvarna Garden
Husqvarna 455 Rancher loses power, have tried the following: fresh premium gas with ams oil 2 cycle oil, new plug, cleaned air filter, runs for a little while but starts stalling out after using about a...
check your fuel filter/gas line in tank you could have a crack in your line that in the fuel till it gets below half tank then sucks air through crack, It's a possibility, other than that, check your exhaust port, but sounds like a fuel problem check your fuel tank vent also to make sure it is venting. Good Luck
May 03, 2011 | Husqvarna Garden
How do i replace the fuel line on the rancher #55. is there any connection in the gas tank or just at the carburator?
Apr 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you change a fuel filter on a husquavarna 455 rancher
Hi Rick,
To change the fuel filter:
1. Drain the gas from the tank and run the saw until it is completely out of gas.
2. Remove the top cover. You might also have to remove the air filter.
3. Locate the fuel line from the tank to the carb. Detach the line from the carburetor.
4. Feed some of the line into the tank if you can. With pliers, pull filter far enough out of tank through the fill hole so you can get the filter and a little of the line.
5. Pull the filter off and replace with new one by twisting it onto the line.
6. With pliers, pull the line back to the carb from the top and reattach to the carb.
Hope this helps. If it does, I'd appreciate your vote. Thank,
Handie Andie
Apr 07, 2011 | Husqvarna Garden
My 455 rancher bogs down when i give it gas it's not even under a load new plug air filter, fuel filter, made carb adjustments like manual said running 93 octane gas.it,s still bogging
Make sure the chain break is releasing all the way. When the saw is not running release the chain break and make sure you can move the chain back and forth by hand. If you can there is a small fuel filter in the gas tank that should be replaced. Make sure the fuel lines are not spongy because they could collasp when the engine is running starving the carburetor for fuel.
Mar 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Saw runs out of petrel and stops, when plenty of petrol in tank
Try opening the fuel cap for a moment to see if tank venting is the problem. If no change, check the fuel filter for plugging and the fuel line that it is attached to for decay or other damage. The fuel line in the tank should be long and flexible enough to allow the filter to flop around to find the low point no matter the operating position. Hope this helps!
Jan 15, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 55 rancher - I rebuilt this saw but now it won't start. Seems like not getting enough gas. What should I check for?
Jun 06, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
May 28, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw kills when I press the throttle
My 372 xp did that and when I talked to the repair shop they even showed me. There is a fiberglass gasket that is used to mount the carburetor to the engine. I have no idea on how this happens, but I saw it with my own eyes. The gasket had actually folded over. They replaced it with a rubber one and have had no problem since. The saw was hard to start, would run as long as I didn't try to cut anything and when I did it would open up and then die. I could be giving wrong information, but that sounds exactly like the problem I was having.
Oct 08, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
211 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
