Question about Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with
I am trying to change the cartridge and do not know how to disassimble
  • 334 Answers
Right on the top of each handle is a decorative cap or "nipple". You can usually pry it up with a fingernail, if not a knife edge will do. They are simply held in place witha rubber O-ring. (they look like a non removable part of the handle)
When you remove that cap, you can access the screw that hold the handle in place. After removing the handle, you will see the brass nut that lets you remove the stem/cartridge.
Make sure BOTH the hot and cold shut off valves are off, even if you are only replacing one side.
Posted on Oct 03, 2009
Testimonial: "excellent. thank you. "
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
Let me know
Jan 09, 2011 | Brother IntelliFax-2480C Fax
Blink red color to check print cartridge
i gotta know, if itz printing or not..if so..
dis is quite common problem..don't panic..
did u changed / replaced the cartridge with original spare or refilled it..
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 30, 2009 | HP PSC 1210 All-In-One InkJet Printer
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Apr 05, 2009 | Delta & Single Handle Shower Faucet
Cant change the ink
Link for manual;
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15402#DownloadDetailAct
Mar 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I have changed the black ink cartridge and my lexmark 125 keeps telling me to change the black ink cartridgeand I can not get the thing to copy for me. All it does is keep telling to change the black...
After you get the carriage centered to remove the ink, power off the printer. If you replaced the cartridge with a new cartridge check cartridge for tape residual that might be covering the copper contacts. ( you may not be able to see this).
If you use a refill kit. Most printer Mfg's insert a chip in all there ink cartridges. This chip tracks when you remove an empty cartridge through the printer software. So it knows you replaced the same cartridge forcing you to buy another.
You can also clean the copper ink cartridge contacts with some alcohol & cotton swabs. (Careful not to drip excessive alcohol onto the bottom of the cartridge). Clean the carriage contacts as well. Re-place the cartridge & try again.
Luck!
Mike
Apr 11, 2008 | Office Equipment & Supplies
Lexmark P315 InkJet Photo Printer Ink Cartridge Problem
Hi, I know this might sound really bad but have you made sure that you have taken ALL the little bits of plastic and covers that are sometimes on the new cartidges?
Also are you using the exact same cartridge as before?
Another thing you could do to bypass the problem is to have your one refilled. That will at least fix the problem for the immediate.
Does your printer have some software where you can run a clean print head and do an align and other stuff. If so you could try those too.
Lets us know.
Oct 25, 2007 | Lexmark P315 InkJet Photo Printer
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with Logo
304 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
