Question about Panasonic Lands Phones
I have a panasonic cordless phone that now says ''line in use'' when it's not. This just happened and I can't seem to fix it. Suggestions?
    President:
  • 1,462 Answers
With this most model of panasonic, you will typically find that the handset will say "line in use" when it is not, and you will have a busy signal when you call the phone from another line.
If you unplug the phone cord from the base, and the line is now clear and you now do not get a busy signal when you call it.
That problem is in the base, and not the phone itself. Its a common defect, that typically occurs after a storm has come through. Unfortunately it is not a setting or an easy component to replace. Your best options are to order a replacement base, or send your base in for repair (the chips that get blown cannot be purchased individually).
Better try to connect the phone to power surge to protect it from further danage.
Before sending the base to factory, try to take the battery out of the phone for a minute or two and then put it back in. Unplug the the phone (jack and power supply) including all extensions, then plug them in again and see whether it works...
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Oct 03, 2009
Why is answering machine volume too low?
Panasonic Cordless Phone - quiet volume - Phones - Gadgets - Whirlpool
forums.whirlpool.net.au > Gadgets > Phones
WhirlpoolJan 4, 2011 - We've just got a Panasonic KX-TG4393 Cordless phone ...objectID=4555), but the volume is extremely low and it's very. ... have a problem hearing messages on the answering machine. ... Looking for any suggestions too.
Panasonic Dect 6.0 4-Handset Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001RTU...
Amazon.com, Inc.Panasonic Dect 6.0 4-Handset Cordless Phone with Answering Machine .... I do not mind the low ring volume because too loud rings bother me but I am listing ...
Panasonic KX-TG6445T DECT 6.0 Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001P80...
Amazon.com, I
Jan 07, 2016 | Panasonic Lands Phones
Panasonic KX-TG2631al 2.4GHz cordless phone is getting interference from crossed lines from another phone and wont receive or make calls
No you need to purchase a device that operates on a different frequency-most hose phone do not change frequencies beside the Bluetooth ones, and it seems your is not. I suggest a 5.8ghz and a store that has a flexible return policy, RadioShack has a decent selection of phones around 50$ give of take, you could also go for a Bluetooth setup--Good Luck.
Jan 31, 2013 | Panasonic KX-TG2631 Cordless Phone
I have the panasonic handset phone. I have three lines. When I pick up the phone it goes automatically to line 3. If I have a call holding on line 1 from the desk phone how do I get to line 1 on the...
A lot depends on what sytsem the 7896 is plugged into. If it happens to be a TA series, you'll go into station programming mode (menu 99) and dial 11. The change this makes is that you will have to dial "9" to get an outside line, or 53x to pick up lines 1,2,3 etc. To get back to idle line preference, dial 12, but a cordless phone should never be set to ILP because you can't call internally or page.
Carl
Sep 21, 2010 | Panasonic KX-TD7896 Cordless Phone
I have 2 Panasonic wireless phones ModelKX-T7885 and a panasonic PBX. One wireless phone will not display F1 thruF4 lines; it displays F9 thru F 12 only depspite reprogramming the unit to default settings....
Hello, Peter.
Try resetting your modem / router that provides the connectivity.
Then, if necessary, re-power (Off and leave for 10 minutes, then On) your phones.
Hope this helps.
Sep 15, 2010 | Panasonic KX-T7885 Cordless Phone
System is busy message when hitting talk
At the main base unit, unplug the power in line for a minute. That fixed mine. It has happened twice...don't know why.
Bob W
Dec 05, 2009 | Panasonic Lands Phones
Phone says in use cannot call out
check that no one else is on the phone line or that a fax or other type of modem are installed, they might be the problem
Oct 17, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Nov 06, 2008 | Uniden Cordless Phone
Dropped calls when cordless phone plugged into it.
I have solved this problem several times by using a splitter at the telephone jack instead of the XDP port on the phone. The extension is programmed to share the port isn't it? That is in program 600.
Aug 21, 2007 | Panasonic KX-T7633 Corded Phone
Cordless Phone. It doesn't work!
The phones base station is burned out, they are not replaced after warranty or repaired, so time for anew phone. Buy a UNIDEN
Jun 30, 2017 | Panasonic KX-TG2302 Cordless Phone...
Lands Phones Logo
208 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
