My LCD model LN-S4095D has no picture or sound. To check whether if the TV is bad, I used Samsung remote to turn on, then source, then menu, and saw on the screen " weak signal ". Is this correct?
    President:
  • 1,779 Answers
Somewhat, take a dvd player and plug it into av1, switch your source to that and see if it's normal.
Posted on Oct 03, 2009
Samsung LN-S4095D HDTV Screen Glitching
look to see if same issue with a DVD etc connected to a rear input.
Jun 07, 2012 | Samsung LN-S4095D 40 in. LCD HDTV
Connect satellite L655-03F to tv samsung LN-S4095D
Assuming your T.V. is set up right, That is, the cable input matches the select input on the remote control check this, try clicking around the input choices while you feed the computer output to the to the T.V. Otherwise you may need to check for a other coveter boxes, It stands to reason, one way or another, you should be able to see the computer image on that T.V. model.
Jul 26, 2010 | Toshiba Computers & Internet
Remote control will not work on Samsung 40" flat screen
I would try a universal remote just to see if it does it on a different one. You may have a defective remote. How long have you had this problem?
May 13, 2010 | Samsung LN-S4095D 40 in. LCD HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Mar 10, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung LN-TFT-LCD Television
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Jul 31, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Source picture changing by itself
litigation- O.k if your tv is cycling through the menu ect. it sounds like you have a bad tact switch.Try pressing the contol panel buttons repeatedly,most of the time the remote is used so the tact switches go bad. Try this out ,it may help to clean the contacts. Just make sure you press them alot,it helps most of the time,if not you may wind up in the repair shop.Have fun and let me know. cooltek Mar,4/08
Mar 04, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Picture appears to be cracked
It is cracked. Maybe not the first layer, but for sure the lcd is cracked. This is the reason why you found it on the garbage. The lcd panel is way more expansive like the tv itself. You can sell it on ebay for parts.
Dec 31, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
Problem with 1080p via hdmi?
are you hooking up a 1080p source..if not then the set will not display the best picture in 1080p mode..
May 07, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
Electro Med Services...
