Question about KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
What is error F 06? It trips out on the spin cycle. F06 flashs on the display. We have replaced the motor. Control board is next. Why. Machine is just three years this month.
    President:
  • 1,462 Answers
An F06 fault code in a Whirlpool Duet washer usually means a motor-related problem. It usually pops up when the drum won’t rotate at all or only very sluggishly
f 06 Drive Motor Tachometer Error (The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer and the Motor control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
*Check the MCU
*Check the Wire Harness
Please rate this solution
RNJ VINODKUMAR
Posted on Oct 03, 2009
I had same code on Maytag front-load 3 year old. When I opened up the machine it turned out that the bearings where completely destroyed. Unfortunately Maytag only sells entire ($400-500) outer tub .vs. the $20 bearing to fix the solution. Going outside of Maytag repairs to fix or find someone to fix. Only other option is to trash entire machine and buy new top loader.
Hope this isn't your problem as well - but easy to figure out. Open up back of machine (at least for Maytag) and take a look at the bearings. Might need to remove a nut or two and the belt to see. Some folks suggest that if you lift the tub you might be able to tell - but I would open the back to be sure. Also - the fine metal dust and grease all over the back of the machine was also a sign my bearings where shot. My counter balance broke as well and pieces of rock like material where under my machine. Hope this helps.
Posted on Mar 19, 2012
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the MCU
Nov 04, 2012 | Whirlpool Washing Machines
The code F06 keeps flashing up on the screen can you help me Paula James
Hi Paula...
F/06 - is refer at Motor tach Error code, control board not sensing motor. If error code appears in the high spin speed mode the door will be unlocked after three minutes.
- Check connections between washing machine motor and MCU (Motor Control Unit)
- Check wire connection on the MCU to the CCU (Central Control Unit) The CCU is on the top of the washer.
Hope helps (remember to rate this answer).
May 19, 2011 | Washing Machines
Flashes F 06 and does go through spin cycle
F06:
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
•Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
•Check the Drive Motor
•Check the MCU
•Check the Wire Harness
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After starting the wash cycle, the machine will stop and 06 will flash then F will flash. The washer will not complet the cycle
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During the wash cycle the machine stops and
Hi
Thanks for using FixYa. Error F06 is your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The spinning cycle stopped and it flashes 06 F
The F06 code on the Duet usually indicates a motor related problem. It is a "drive motor tachometer error". It means that the control board is unable to properly detect motor speed. Check the electrical connections and wiring between the motor and the motor control board and between the motor control board and the central control board. Try unplugging and reseating the connections to clean off any corrosion. If that is unsuccessful, then I recommend contacting an appliance technician for assistance. Sorry for your trouble and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER STOPS WORKING AND FLASHES 06 F
F06
Drive motor tachometer error
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool GHW9400L4
f06 is an error pertaining to the motor control board loacated behind the lower acess panel mounted in the left fron corner, first check for loose wire connection, sometimes alot of water/moisture will trip the control, remove and refit the wire harness leading to the control a few times and look for physiacal damage to board as well.
Nov 10, 2008 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
458 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
