Question about Lexmark P4350 All-In-One InkJet Printer
Copy machine copies and then stops after about 2 times
I have not had problems with our machine, but after refilling our ink cartridges once it was not coping well so I bought new ones. Now it only copies a couple of times and then says cartridge error.
We have been told it has lost memory and are not sure how to fix that can you help us.?
  • 233 Answers
Have a Samsung Inkjet FAX SF-370. Changed ink cartridge with a refill one, couldn't read the document that I copied. I thought it was the refill cartridge so I bought a brand new one. Same Problem - when I...
first off when you replace the cartridge you have to press cartridge button and replace the cartridge and then press 1 for new cartridge then let the machine print out a alignement page press the correct button and then press start button if you have done it try the following
unplug the machine hold down the clear/stop button while you plug the machine in when you see your country name in the display press start button that will revert the machine back to factory defaults that should do the trick if not the head could be faulty
Apr 06, 2011 | Samsung Office Equipment & Supplies
Canon mp190 error e5, with refilled cartridge will not reset, even though the error only came on after the printer had already worked with the newly refilled cartridges. Ive tried the reset/power button...
Hi. Try to reset the printer using the procedure below.
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE – pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Aug 21, 2010 | Computers & Internet
I'd like to refill the ink cartridge on my Philips
Yes, some have a chip on the cartrige unit, they cannot be reset.
Buy a new unit.
Sometimes using competitve ink in this machine can cause other problems.
The copies are light with background and with streaks, also sometimes the toner might be spilling below the developer housing or copy cartrige unit.
Good luck
Oct 14, 2009 | Philips Office Equipment & Supplies
HP78 refills work but after 20-30 copies one or more colors simply stop working.
Be careful with the ink refills...the electronic on the back of the cartridge may only last 2-3 refills until they start failing and even then they corrupt your driver files. Use caution past 2 refills of HP cartridges.
Sep 17, 2009 | Office Equipment & Supplies
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
Fax keeps saying out of ink
You can also put the machine in serves mode by unplugging the power from the machine, press both the the copy/help and the stop buttons at the same time, hold them and plug back the power until you see TF662B service mode.This also works well with refill cartridges. YJ
Feb 05, 2009 | Sharp UX-B750 Inkjet Fax
I've refilled the ink cartridge & have not been able to decent copying quality since. I've clean the cartridge a number of times & still get broken copy. When I took the cartridge back to the...
if you are using refills the first thing i would do is take them out and buy originals as when you get them refilled that all they do is refill them. they do not replace the printhead which seems to be the problem you have
you can also scroll through the menu to clean and algin printhead
Apr 22, 2008 | Canon FaxPhone B95 Plain Paper Inkjet
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Ink cartridges
i advice you to use the compatible cartridges, else maybe can outhers cartridges make a damage to your printer.
if you want more copies find anouther printer
Nov 04, 2007 | HP DeskJet F380 All-In-One Printer
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark P4350 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
