Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold dishwasher not spraying after filling up with water have to push cancil to drain water
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
Posted on Oct 01, 2010
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
Aug 22, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our Whirlpool Gold dishwasher does not drain. What
Hello there:
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
MotorIf the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer.
Mar 20, 2010 | Dishwashers
Stopped runing
If you Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
Feb 22, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold built in dishwasher fills, lights are on but does not spray water or drain.
This is a possible sign that the water pump has failed in some way or the control circuit for the water pump has failed. You MIGHT be able to access the pump without pulling the dishwasher out of the cabinet space through the front kick panel. You may have to remove a few screws to get it off. You'll have to work low, on your belly, but it'll beat taking the dishwasher out and turning it on its side. Especially considering it's probably still full of water!
With the machine on and "running" at the point where it's supposed to be spraying or draining, check for voltage at the pump. If you see 120V there, the pump motor has failed. If you don't see any voltage, the control board assembly has most likely failed in some way. It's located at the top of the door. Again, remove a few screws and tilt it out. I would first check for a blown fuse, burnt board, etc.
I hope this helps! :) Let me know if you need any further assistance in this matter.
Feb 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Food particles on dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GU2400XTP Built-in Dishwasher Logo
122 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
