Question about Logitech LX5 (9314510914) Mouse
Logitech MX1000 Cordless Mouse Will Not Power UP
Have connected the Logitech MX1000 Cordless Mouse cradle to my PC via the USB cable but the cradle will not power up and the mouse is not charging, but the equipment was working prior to a desk move.
Is there anything I can try to get the mouse active again ?
5 Suggested Answers
SOURCE: Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Posted on Mar 24, 2008
  • 8 Answers
SOURCE: Can't reset my cordless Logitech mouse
you should hold the reset button on the receiver for 5 seconds. let it go and immediately press the reset button on the mouse once. If done in this order it should be ok.
Posted on Aug 23, 2008
  • 294 Answers
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
Posted on Mar 28, 2009
  • 1901 Answers
SOURCE: change battery
If it is cordless, it has batteries. You can usually tell if the small red light is off on the bottom.
Most mice have the battrey compartment in the rear half of the top of the mouse. The rear half slides off. Something like this:
Yours will probably hold 2 AA batteries. If it is one of the smaller ones it may have the battery compartment underneath and take 2 AAA batteries.
Hope this helps.
Thanks for using Fixya.
Posted on Feb 09, 2010
  • 3 Answers
SOURCE: Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
Posted on Aug 03, 2010
0 characters
1 Points
MX1000. left click and drag (or highlight) does not work. Resetting does not solve the problem
try re installing the software,3,2,4,5/cl/us,en/kw/
verify all connections are tight use the ps2 adapter or don't [if your using usb]
does the left click feel funny like its bottomed out or no click if so probably the mouse also try fresh batteries i hope this helps and please vote
Dec 08, 2010 | Logitech MX1000 Laser Cordless...
The mouse appears to be on but the pointer on the screen does not move. The keyboard is still working. The re-set button does not correct the problem. Re-booting the computer does not work.
The same thing happened to me today. Somehow, something uninstalled my setpoint mouse software?!?!
While I was actually using the mouse?!?!
(it just stopped moving all of a sudden)
Don't ask me how/why this happened but I fixed it by unplugging the MX1000--both power and usb connection, plugging in an old serial mouse, rebooting the computer, opening mouse properties, going to the Mouse settings (in Control Panel), clicking the Setpoint tab, telling it to look for an update to the Setpoint program, letting it download and install the program automatically, then unplugging the old serial mouse, plugging in the MX1000 (usb first, them Power) and Voila'! Working as it should once again, even without a reboot. :o)
I love this mouse--perfect size, fast, programmable, accurate, long battery life, Perfect!
Aug 06, 2010 | Logitech MX1000 Laser Cordless...
Im having difficulty in charging my mouse -my stand is plugged in -i've cleaned the contacts -i've reset several times and it still doesnt charge
Verify with a tester that the cradle is supplying power. If it is, the mouse rechargeable battery might be gone; if it's one of the models with common NiMh AAAA ("pencil thin") batteries inside, you can even replace them by yourself.
Jan 03, 2010 | Logitech MX1000 Laser Cordless...
How to replace batteries on logitech cordless mouse??
Dec 08, 2009 | Logitech MX1000 Laser Cordless...
The mouse pointer on the screen has the HOUR Glass continually flashing when a Mobile Data Connect card is connected (via a USB Port) any suggestions or advice please
It may mean that the port maybe too slow to the mobile mouse and the data card to use.
So it is taking undue long to load data.
Nov 05, 2009 | Logitech MX1000 Laser Cordless...
I have found that the Bluetooth adapter sometimes has trouble staying reliably connected through many types of desk material. Try getting a USB extension cable and relocating the bluetooth transciever closer to your keyboard/mouse work area.
Sep 06, 2009 | Logitech MX1000 Laser Cordless...
Logitech LX5 (9314510914) Mouse Logo
18 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
