Question about Wacom Intuos2 (XP-110) Digital Pen
I have an intuos two pen w board and only the eraser side seems to work but not draw. help
SOURCE: The cursor stops moving.
I have found the same problem here. I use my plasma as a monitor and that interferes with the tablet when up close.
I also read somewhere it also can be your wireless router that causes the same problem. Perhaps using a different channel in your router preferences.
Posted on Apr 02, 2008
SOURCE: Tablet Pen end not erasing in Photoshop elements
It might be your tablet properties. Check in there and make sure the eraser is set to be the eraser.
Posted on May 25, 2008
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
SOURCE: cover of the drawing surface come off
The drawing surfce is not glued down and should never be glued down. It is replaceable...
It is basically held on the tablet by an adhesive strip (Double Sided Tape) along it's top edge. I was a little worried too, when after spending some time in Photoshop, it lifted away as if stuck to my wrist.
This is not a fault and it will just lay back in it's recess, no harm done.
NEVER EVER glue it down, or when it comes time to replace it, you will not be able too. If it is peeling up and not laying flat, buy a replacement.
Posted on Aug 23, 2008
SOURCE: how to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Posted on Feb 22, 2009
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
Jun 28, 2012 | Wacom Computers & Internet
I need help! My intuos 3 pen is wacking out! it is over selecting things... how do i fix this? my mouse is not doing it, but the pen is. I took it apart and cleaned it...which seemed to help a little...but...
Soooo many people have this problem. Try hitting the pen head into your palm and do the same with the eraser. This worked for me. Something about the humidity and making the pressure thing in the pen stick. I hope this helps.
Mar 30, 2010 | Wacom Intuos3 Graphic Tablet
When I go into certian programs like inkscape or the newer Gimp my wacom pen wont draw,but it will select items. yet if I use an older gimp 2.0 it works fine I have the intuos 3 ptz -431w actually it did...
I didn't solve it myself (a lady named Linda deserves the credit) ... but the solution at the following URL worked for me when I encountered the same problem with inkscape0.47 and intuos 4 wacom tablet pen:
http://inkscape-forum.andreas-s.net/topic/200534
Thanx, Linda!!!
cheers
zookumar
Aug 07, 2009 | Wacom Intuos3 Graphic Tablet
Stylus for Intuos 3 sticks sometimes
it is of the coz in the inside of the there is errore
Mar 09, 2009 | Wacom Stylus Pen for Graphire4
How to take apart Intuos pen
Malice
Jan 18, 2009 | Wacom (EP130EPE) Digital Pen
Intuos pen
Yes, download the new drivers at the Intuos site
Aug 14, 2008 | Wacom Graphire Intuos Pen (GP300ESE)...
Mar 21, 2008 | Wacom Intuos3 6x11
Graphire 3 tablet pen troubles
scrap the graphire and get an intuos....i have the same problem....I think the pens are cheap...you might need a new pen. try borrowing someone with an intuos pen.
Sep 12, 2006 | Wacom (EP130E0W01) Digital Pen
Wacom Intuos2 (XP-110) Digital Pen Logo
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
Ed Mac
k24674
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
