Question about Bushnell Pinseeker 1500 Rangefinder
Inconsistent and unreliable readings
Sometimes it works and sometimes it doesn't. Sometimes I get an accurate reading and sometimes it's way off. Also, frequently can't get any reading on a flag, but seems to work when pointing at a larger object. Didn't have these problems when I first started using it in June.
    President:
  • 2,976 Answers
A flag is a hard object to get a reading on. It constantly moves and the sound or light waves (depending on the model) will not be reflected consistantly. Clean the sender lens and the receiver lens and install new batteries. Recalibrate the unit using something stationary, like a FLAT wall.
Posted on Oct 03, 2009
Testimonial: "Thanks for the quick response. I'll try the recommended fixes. In particular, I'm intrigued by the recalibrating by aiming at a flat wall. Thank you!"
Rangefinder pinseeker 1500 was damaged in car accident. will not show all the numbers. can i send and get it repaired?
Posted on Dec 28, 2009
Fuel gauge not working
You need to most likely drop the fuel tank out of the car and replace the fuel tank sending unit. Have this conformed by the dealer as it is a very laborious job and requires some special tools for the fuel lines.
Mar 19, 2014 | Dodge Caravan Cars & Trucks
Causes overheating
bad thermostat or make sure the probe is all the way in so it can get a accurate reading, sometimes the thermistor (probe) can work its way out and not get a reading
Sep 29, 2013 | Jacuzzi Pool & Spa
Oven temp is inconsistent. Sometimes it works but most of the time it doesn't. Yesterday we set it at 350 degrees. Two hours later it only came up to 250 degrees. I've replaced the oven sensor but...
Is this a gas oven? gas ovens rely on ignitor/glowbar ignition. The system uses amp draw to open the gas valve. If the ignitor is off a tad in amp draw then kickin or bangin on the stove sometimes makes that puppy work.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 20, 2011 | Kitchen Ranges
I am getting inconsistent odometer readings. For a 23 mile round trip it will sometimes read 47 miles sometimes 23.
Newer car have an electronic speedometer and the problem can be a bad sensor at the transmission or to the computer. The sensor picks up the signal through a magnetic device in the transmission, this sensor could be at fault.....
Feb 13, 2010 | 2001 Hyundai Accent
Gas guage not reading accurate
Your sending unit inside of the fuel tank is probably faulty. Unfortunately you have to drop the tank to change it.
Sep 08, 2009 | 2000 Chevrolet Silverado
Doesn't Read Disc
I had the same problem. Just wipe the laser lens with a smooth cloth.
Jul 09, 2009 | Nintendo GameCube Console
Brisbane sd48 doesn´t read SDHC cards
I believe the Brisbane SD48 radio can only recognize memory cards up to 2 GB. Your SDHC memory cards probably exceed this 2 GB limit.
Jun 17, 2009 | Blaupunkt Brisbane SD48 Car CD/ MP3 Player
DVD Player reads Unreliably
your dvd needs to be serviced have a tech look at it, if that does not fix your problem replace your dvd for another one. good luck
Jan 06, 2008 | Televison & Video
Bushnell Pinseeker 1500 Rangefinder Logo
824 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
