Question about Dell Inspiron XPS Gaming Mouse Pad KU170
Dell XPS One Blue lighted buttons on right of screen do nothing
Blue lighted buttons on right of screen do nothing but beep when touched.
dragon_rag27
  • 89 Answers
SOURCE: Dell XPS fan come on but nothing else powers up.
most likly a hardware issue i would recomend taking it into a shop what is your computer experience?
Posted on Jan 08, 2009
  • 629 Answers
SOURCE: I have a Dell XPS
this is either a motherboard, AC or battery problem. Isolate it by removing all attached devices, then emove the battery and power on the computer with just the AC adapter. If that does not work, remove try to use another AC, and another battery. if using another AC and another battery does not work, run the diagnostics on the dell laptop. press and hold the FN key, then press the power button. see if that will give you any error and take note if any of the lock lights will come up and/or blink.
Posted on Apr 08, 2009
  • 630 Answers
SOURCE: I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Posted on Jul 25, 2009
  • 266 Answers
SOURCE: my dell xps m1530 laptop seems to be on but nothing on screen
Remove the battery and power cable from the system and press the power button for about 5 seconds, then plug in the charger and start the laptop. it will work. shutdown it and put the battery back and start once again . now you can see its working
Posted on Feb 12, 2010
  • 3 Answers
SOURCE: Dell XPS M2010 Starting Problems
If the problem is bad caps on the motherboard you can probably get your computer to start again. Plug into ac power. Turn on computer and if you get the bluethooth and power light only just leave it sit this way for a while 15 to 30 minutes. Now press the power button and it will shut off, turn it back on and repaet until it loads. It may partially load a couple times until the caps get warm enough that their voltages return to close to normal so it will load all the way. This is not a repair but a way to get back into the computer so you can backup your data before having the board repaired or replaced. This has worked several times on the computer I am working on for a customer, the motherboard needs replacing and that is going to be the best solution for my customer.
Posted on Jul 29, 2010
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
Dell xps one just blinking blue light
Oluwafemi.,
Which xps one do you have? Which diagnostic light is blinking blue? We need more information to help resolve this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Community
Dell xps 13 beeps constantly
If your are tapping the F key repeatedly it will beep after the first one. If you don't tap, does it still beep? Try remove ALL Media DVD,CD,USB. shutting down, unplug, remove battery, plug in, reboot.Press and hold the F-8, Take a look at this : http://en.community.dell.com/owners-club/xps/f/3681/t/19278287.aspx
Jan 23, 2013 | Dell Studio XPS 13 (dydwgn3_4) PC Notebook
Dell xps m140 press the power button green lights come on then go off nothing ever comes on screen
dead motherboard or power supply or powercord and or battery try another power cord if nothing take out battery and try to start with out battery if neither works then it will need either a motherboard or power supply
Oct 17, 2010 | Dell Inspiron XPS M140 Notebook
Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Apr 29, 2010 | Dell XPS 420 PC Desktop
My dell xps m1530 laptop seems to be on but nothing on screen
Feb 12, 2010 | Dell XPS M1530 Laptop
Dell XPS M140. No Sound. Checked lighted button,
Make sure any programs that consist of sound for example " Soundman" is running this can cause a conflict with your audio. Check for updates if you can
Jul 30, 2009 | Dell Inspiron XPS M140 Notebook
If they've changed everything else, why didn't they replace the power supply? That's the next part to target for replacement, other than the on/off switch (or button) itself. With no system board beep codes it's apparent that the mobo isn't gettting any juice at all.
Also try disconnecting everything from the mobo but the power supply - including pulling add-on cards. One or more attached devices may be contributing to the problem. If it comes to life start adding things back until it fails - you've just identified the culprit.
Good Luck!
May 22, 2009 | Dell Inspiron XPS M2010 Notebook
Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Mar 11, 2009 | Dell Computers & Internet
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Dell Inspiron XPS Gaming Mouse Pad KU170 Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
