Question about Cell Phones
Sciphone fails to register with network, no bars, but sim card has contacts in phone?
  • Cell Phones Master
  • 928 Answers
First you need to make sure that your phone is actually working in the band that your wireless carrier uses. If your carrier uses a 850mhz. band and your phone is a triband without the 850mhz. band it will always says emergency and would never register. Borrow another Sim card that uses either 1800 or 1900mhz. band. If it register, then the phone is triband and your wireless carrier uses 850mhz. band. Another thing is to check the imei number, if they don't match, you need to fix'em. Compare the imei numbers (*#06#) with the one in the battery compartment.
Posted on Oct 03, 2009
What sim card do i need to use i have the latest sciphone form hongkong and i cant use my 3g sim card from optus and the guy at the shop couldnt help me so what sim do i need to use living in australia...
Go to this website www.i9forum.co.uk register and check the forum out for a solution, I've had a quick look but its mainly about mms & gprs. If this is what your after the settings the instructions are there on how to set it up.
I'm with Telstra 3g and have the new sciphone i9 3gs and it works great.
Apr 18, 2010 | Dual Electronics CECT P168 Cellular Phone
My sciphone is reading my sim card but cannot make call. I am able to access all phone numbers on it but I cannot make calls. Do I need to set up the network somehow? I have AT&T with full bars on my...
Hi,the problem is obviously from the network settings on the sciphone,here is a solution,
1,Try to re-insert the sim card in the phone.
2,Go to the mobile connections on your sciphone and ensure the radio(service) connection is switched on.
3.If after these steps,the problem persists,then it seems your sciphone has a network problem which can only be fixed by a mobile phone engineer.
Take care
Mar 18, 2010 | Cell Phones
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
I get an opening message: "SIM card registration failed" - what does this mean? then i can't receive nor send any msgs.
1, The sim card is turned off, if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
May 08, 2009 | Nokia 6300 Cellular Phone
Sim card wont register
You SIM card is inactive. You have to make at least 1 paid call every 6 months otherwise your sim is deactivated. If it's new sim has to be activated.
Rate me if helped.Thanks.
Apr 14, 2009 | Nokia N91 Cellular Phone
I just get sciphone i68, and i inserted the sim card [virgin mobile precisely] and the network bar shows 5 bar, which suppose to indicate that the network is ok, but if i try to call, it always indicated...
i have a i68 8g sciphone i put my sim card in the phone and it won't let me dial any numbers i mean i can dial but all it says is fail and it won't let me choose a network i have service but when i look at my main screen it says sims card 2 closed because i closed it but in slot one it says emergency how can i fix the problem please help!
Apr 10, 2009 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
138 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
