When it spin a burning rubber smell is very strong and the wash is not ready for the dryer because it is still very wet. My washer is Maytag model LA810 series 01 serial# 013122 LR Ihave changed the belt (2)underneath and they feel loose and cannot spin the pulleys. one of the belt was crack in two places. Do you think I need a new washer?
  • 334 Answers
New washer? probably not, but you very well may need a new tensioner pully spring.
Either the new belt is the wrong size, or it is installed improperly, or the tensioner is not providing enough tension to keep the belt tight. Make sure the moving parts are oiled. Sticking parts can also prevent the tensioner from pulling properly.
Posted on Oct 03, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
Nov 28, 2011 | Washing Machines
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer has a burning smell.
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Oct 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
236 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
