Question about KitchenAid Ovens
My oven will not turn on. I notice the clock is not on but the burners do work. I have a kitchenaid superba oven with a glass cooktop.
  • 454 Answers
You can download an electrical schematic from the kitchenaid web site. In the back of the stove, you will be able to trace the wires to find a loose connection. Be careful - make sure you disconnect the power before you start. You don't want to accidentally touch 220V.
Posted on Oct 03, 2009
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Electronic control board
If you are hearing a clicking sound, that would be the igniter trying to light the gas, however you said elements not heating up which says it's electric... hmmm. If it's electric, try the broiler and see if the element comes on. It's pretty easy to troubleshoot by process of elimination. By all means do not try and repair it yourself unless you are qualified working with electrical.
Jun 14, 2017 | KitchenAid Ovens
I have a Kitchenaid superba convection/gas oven model KGR1607hblg (?) I had soup overflow from the top burner and now the burners will not ignite. When turned on they will spark but nothing catches.
Make sure that all the soup was cleaned out of the little holes in the burner that the gas comes out of. You can use a toothpick or some other small object like that to try to clean them out
Mar 23, 2011 | KitchenAid Ovens
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Kitchenaid superba oven
Hit the options button and check that the "Sabbath mode" setting is off. I note that October 20th was a Tuesday but the internal clock year could be incorrect.
Oct 20, 2008 | KitchenAid Ovens
Ovens Logo
588 people viewed this question
Top KitchenAid Ovens Experts
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
