I purchased a NIT Backup now EZ 320 GB How can
I purchased a NIT Backup now EZ 320 GB How can I open and view a file on this
back up
  • 591 Answers
Look at "My Computer" for whatever drive letter is assigned to the drive. Right-click and Explore, all files should be there. If not, then you will need to go into Folder Options and set so you can see Hidden Files. All files will then be visible.
Posted on Oct 04, 2009
I restored a backup from NTI EZ backup but my Outlook contacts and current emails were not recovered. Do I have any chance of restoring them?
You can search your computer for files with a .pst extension by doing a search like *.pst. Once located you can grab them and restore them by opening outlook and choosing to import those files. A bit of a techie solution can be found here How to import from pst file back to Outlook Express AnandTech Forums
Aug 31, 2014 | NTI Backup Now EZ
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
I originally downloaded NTI Backup Now EZ software from the Toshiba website to use with an external Toshiba hard drive I purchased and have been running both "File and Folders Backup" and...
Hello bobdurack
I'm not shure this is the solution but it's a possibility : has the letter of your external Toshiba eventually changed ?
Regards ,
fanaudi .
Mar 28, 2011 | NTI Backup Now EZ Software
I can not copy more that 2 GB toTranscend StoreJet 320 GB? Why?
This is most likely because your hard disk is formatted using FAT32 which has a limitation of 2GB file size. Backup your data in another location and format the disk to NTFS and you should be able to copy that big file.
Mar 08, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Jan 08, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
How to use one touch backup in 320 GB transcend hard disk
Just hook it to the computer with the supplied usb cable and once the computer has reconized it you just press the one touch button on the hard drive, you can also drag and drop files by opening it going through "Mycomputer" and selecting the drive. you can also get the manual here if you need it.
Dec 01, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
I have been using 40GB Apricorn EZ BUS drive....
You may use data recovery software to see if you can rescue the files. It may unable to recover all the files, but at least most of them.
Oct 14, 2009 | Apricorn Ez Bus Mini 40 GB Hard Drive
How to make prtions for the 320 gb harddis
You can use a program called Partition Magic to make changes to the HDD without losing any data.
Please Rate Me if this Helps
Apr 15, 2009 | Computers & Internet
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
293 people viewed this question
David Payne
David Payne
