Question about La Pavoni Jolly (PA-JL) Electric Burr Grinder
Not grinding cogs seem to be stuck, how to take
Not grinding! cogs seem to be stuck, how to take apart?
I have a 2002 Polaris Ranger 500 the 4x4 button
There is a big serrated washer that engages the plastic cogs to make the 4wd work.Either the magnet is not pulling in the washer or your white plastic cogs are broken.I have had my 2005 700 apart.If you are mechanically inclined it will take a a good 1.5 hrs to get it all apart to inspect it.
Sep 29, 2014 | ATVs
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
Getting see documentation message
sometimes this is just a simple trask of cleaning the ink off the rails of the ink carriage.try that first and see if it rectifies the grinding sound. also check that you have not got soemthing stuck in the cogs on the R side of the platten roller mechanism
Jun 23, 2009 | Epson Stylus RX580 InkJet Photo Printer
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
ADF noise and rollers not moving
Dear Hs87 If there is no paper stuck/jam inside the printer and if the motor works fine, plz check again all the threats, there might be a broken threat or untight threat Thanks
Jul 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
La Pavoni Jolly (PA-JL) Electric Burr Grinder Logo
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
